Re: Cubic inches and boost
[Re: FastmOp]
#2204922
11/30/16 01:13 AM
11/30/16 01:13 AM
Posts: 486 IL
knyech1
IL
That's a Magnuson style, I need to ask what fuel and what's the designated intent. If it's pump gas and mostly street you should be fine.
My turbo big block is 12 to 1 but it's race gas. C-16. It has no detonation at 30PSI NOT a Magnuson style...The factory supercharger and the Magnuson are completely different from a design perspective. Magnuson uses roots style rotors from Eaton (same as an Edelbrock supercharger) and is far less efficient than the IHI screw compressor that comes factory.
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
[Re: hudsonhornet7x]
#2204928
11/30/16 01:18 AM
11/30/16 01:18 AM
Posts: 486 IL
knyech1
IL
OP: Why aren't you going with a factory longblock?? There are guys running a nitrous plate setup just aft of the throttle body with a smaller pulley and Diablo tuner running 9's in a factory weighted (~4500#) hellcat! You don't really need any more stroke; just add boost. The factory stuff is pretty dang stout and for the price of a longblock, you might be wasting money going a different route.
knyech1-
[Re: FastmOp]
#2204939
11/30/16 01:31 AM
11/30/16 01:31 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Hope I helped a little. The Challenger is for sale. I got bored with it and don't want to take the drive ability out of it with a,stroker and such. The wife can get in it now and drive it to the grocery store lol.
I like your build, your going to have a fun ride. Is this motor going in the Hornet? You did, Thanks a lot! The car is a 68 Charger. Pure twin h power for the Hudson!
[Re: knyech1]
#2204943
11/30/16 01:34 AM
11/30/16 01:34 AM
Posts: 1,541 USA
hudsonhornet7x
USA
OP: Why aren't you going with a factory longblock?? There are guys running a nitrous plate setup just aft of the throttle body with a smaller pulley and Diablo tuner running 9's in a factory weighted (~4500#) hellcat! You don't really need any more stroke; just add boost. The factory stuff is pretty dang stout and for the price of a longblock, you might be wasting money going a different route. I bought a bare block before the short blocks were available. I also have a bunch of different Gen III internal parts and figure I could get something to work. Here is what I have: New factory 6.4 crank New Factory Hellcat rods and Pistons Manley 300m 6.125 2" journal connecting rods Manley 4.09 bore platinum series pistons Good stuff but it's kind of like legos that don't match lol. Figure whatever way I go I will have to buy something.
#2204976
11/30/16 02:12 AM
11/30/16 02:12 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think with the Manley pistons and rods you already have, might as well go with the Manley 4.05 crank. Dont know your comp height on the pistons but if they're the 1.09" that combo will work to but compression will be higher.
Mopar to the bone!!!
#2204992
11/30/16 02:25 AM
11/30/16 02:25 AM
72Swinger
Nebraska
Ok, sell what you have except for the pistons and do the 398" deal with the 6.20 rods. Would be a killer,solid combo. That is exactly what I would build, except my broke a$$ would be using a 5.7 block.
#2205165
11/30/16 12:19 PM
11/30/16 12:19 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
My son is getting ready to start his 6.1 build. It will be boosted not sure if spray or turbo but leaning more turbo. FI w/Megasquirt. What do you think the power limits are with the stock crank using aftermarket rods and pistons? thx matt
[img] [/img]
#2205179
11/30/16 12:56 PM
11/30/16 12:56 PM
Posts: 1,541 USA
hudsonhornet7x
USA
From what I have read, srt cranks are good to 1000hp. The factory oiling is what does them in at high rpm.
#2205196
11/30/16 01:26 PM
11/30/16 01:26 PM
clonestocker
Tucson, Arizona
From what I have read, srt cranks are good to 1000hp. The factory oiling is what does them in at high rpm. Is this correctable or is it inherent?
[img] [/img]
