Re: Easier way to remove center steering link?
[Re: 70satelliteguy]
#2200782
11/22/16 09:14 PM
11/22/16 09:14 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The key to the pickle fork method or even hammer onto knuckle method. The piece you are hitting must be solid or held solid. If not all the force from the hammer goes into moving the fork instead of driving it in.
Just like hammering a nail into wood. If the wood is not on something solid, like you are holding it. The nail will not drive in.
[Re: Sport440]
#2201030
11/23/16 03:27 AM
11/23/16 03:27 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
That's the method I use, taught by older mechanics. So simple and works so well. Only way to do it imo
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: GoodysGotaCuda]
#2201106
11/23/16 11:35 AM
11/23/16 11:35 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Harbor freight ball joint separator. Load it up and just tap it with a hammer. Yep, if the hammer alone doesn't do it this does and no damage.
#2201416
11/23/16 08:46 PM
11/23/16 08:46 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Throw the pickle fork in the junk metal pile. Get one of these pullers. Turn the bolt until you think it won't take any more and whack the link as close as possible to the joint. It'll pop right off.
[Re: feets]
#2201483
11/23/16 10:48 PM
11/23/16 10:48 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Throw the pickle fork in the junk metal pile. Get one of these pullers. Turn the bolt until you think it won't take any more and whack the link as close as possible to the joint. It'll pop right off. I agree with tossing the fork in the trash, but get a SET of pullers in as many sizes as possible and do as Feets says. It's the right way!
[Re: Sport440]
#2201485
11/23/16 10:51 PM
11/23/16 10:51 PM
Posts: 2,731 541 slobovia
A990
541 slobovia
That's the method I use, taught by older mechanics. So simple and works so well. Yep, been using this method for years. It even works on the upper ball joint, especially if you leave tension on the torsion bar to assist (just be sure to leave on the castle nut). Get that puller too, it really works well. The pickle fork makes a good door stop/wedge and kindling splitter.
[Re: Pacnorthcuda]
#2201576
11/24/16 12:48 AM
11/24/16 12:48 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Throw the pickle fork in the junk metal pile. Get one of these pullers. Turn the bolt until you think it won't take any more and whack the link as close as possible to the joint. It'll pop right off. I agree with tossing the fork in the trash, but get a SET of pullers in as many sizes as possible and do as Feets says. It's the right way! HF has a multi size set for as good price. Has worked for all my needs. Teeth that grip the item you are attempting to pul could be a bit thinner, but has yet to fail me.
[Re: Sxrxrnr]
#2201590
11/24/16 12:58 AM
11/24/16 12:58 AM
RapidRobert
Agreed, a HF one & trim the jaws slightly as/if needed for a dead on grip/fit & as said put some tension on with that & hit both sides at the same time with good sized hammers. Any issue as was said I pull the whole assy & get it on the bench for a less damaging breakdown. Hammers are always my last resort but are needed on occaision
