Easier way to remove center steering link? #2200664
11/22/16 06:06 PM
11/22/16 06:06 PM
Penna
70satelliteguy Offline OP
Penna
I am using a pickle fork. Drivers side easily comes out with a few hits but the passengers side is a PITA. Am I missing something? I have been pounding on it from different angles for awhile with no luck.
Thanks Mike
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2200667
11/22/16 06:19 PM
11/22/16 06:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Try this. If you have room, back it up with another heavy hammer.
Re: Easier way to remove center steering link? [Re: John_Kunkel] #2200712
11/22/16 07:39 PM
11/22/16 07:39 PM
Penna
Penna
Thanks will try!!
Mike
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2200782
11/22/16 09:14 PM
11/22/16 09:14 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The key to the pickle fork method or even hammer onto knuckle method. The piece you are hitting must be solid or held solid. If not all the force from the hammer goes into moving the fork instead of driving it in.
Just like hammering a nail into wood. If the wood is not on something solid, like you are holding it. The nail will not drive in.
Re: Easier way to remove center steering link? [Re: Magnum] #2200833
11/22/16 10:42 PM
11/22/16 10:42 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Sometimes it easier to just unbolt the idler arm and separate them on the floor. twocents
...FAFO...
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2200880
11/22/16 11:46 PM
11/22/16 11:46 PM
AndyF Offline
AndyF  Offline
Using the correct tool helps a ton. All you have to do is tighten the jaws with a wrench and then pop it lightly with a hammer and it breaks free.
Re: Easier way to remove center steering link? [Re: John_Kunkel] #2200915
11/23/16 12:16 AM
11/23/16 12:16 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That's the method I use, taught by older mechanics. So simple and works so well.
Re: Easier way to remove center steering link? [Re: Sport440] #2200926
11/23/16 12:32 AM
11/23/16 12:32 AM
IN
ahy Offline
ahy  Offline
IN
I use a puller... a simple tool with screw and pull arms. I have a couple sizes. From memory, the one that works on that joint is an AZ sourced generic tool. Set it up, put some pressure on the puller and if that does not do it, a light hit with a hammer always does. Even on ancient joints. Leave the nut on loose to catch the parts when they pop.
The trick is to pick the puller so it can fit, put pressure on the joint and not tear up the boot.
A pickle fork almost always works... but with collateral damage. No thanks!
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201008
11/23/16 02:33 AM
11/23/16 02:33 AM
AndyF Offline
AndyF  Offline
Agree. The pickle fork is only for wrecking yard use where you don't care what you damage. If you are working on your own car then use the correct tool.
Re: Easier way to remove center steering link? [Re: Sport440] #2201030
11/23/16 03:27 AM
11/23/16 03:27 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
Only way to do it imo
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201031
11/23/16 03:30 AM
11/23/16 03:30 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Harbor freight ball joint separator. Load it up and just tap it with a hammer.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Easier way to remove center steering link? [Re: GoodysGotaCuda] #2201106
11/23/16 11:35 AM
11/23/16 11:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yep, if the hammer alone doesn't do it this does and no damage.
Don't be the exception.
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201116
11/23/16 11:50 AM
11/23/16 11:50 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I use my pickle fork when my garage door sticks. Not good for anything else.
Re: Easier way to remove center steering link? [Re: GomangoCuda] #2201175
11/23/16 01:31 PM
11/23/16 01:31 PM
Penna
Penna
I do have a small puller and a good Hammer. Will let you know which one does the trick!
Thanks Mike
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201404
11/23/16 08:24 PM
11/23/16 08:24 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thanks Mike
Use the combination, create tension with the puller, then hit with the hammer. It will come out. up
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201416
11/23/16 08:46 PM
11/23/16 08:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Throw the pickle fork in the junk metal pile.
Get one of these pullers.
Turn the bolt until you think it won't take any more and whack the link as close as possible to the joint. It'll pop right off.
- Stu Harmon
Re: Easier way to remove center steering link? [Re: feets] #2201483
11/23/16 10:48 PM
11/23/16 10:48 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I agree with tossing the fork in the trash, but get a SET of pullers in as many sizes as possible and do as Feets says.
It's the right way!
Re: Easier way to remove center steering link? [Re: Sport440] #2201485
11/23/16 10:51 PM
11/23/16 10:51 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Yep, been using this method for years. It even works on the upper ball joint, especially if you leave tension on the torsion bar to assist (just be sure to leave on the castle nut).
Get that puller too, it really works well.
The pickle fork makes a good door stop/wedge and kindling splitter.
Re: Easier way to remove center steering link? [Re: Pacnorthcuda] #2201576
11/24/16 12:48 AM
11/24/16 12:48 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
It's the right way!
HF has a multi size set for as good price. Has worked for all my needs. Teeth that grip the item you are attempting to pul could be a bit thinner, but has yet to fail me.
Re: Easier way to remove center steering link? [Re: Sxrxrnr] #2201590
11/24/16 12:58 AM
11/24/16 12:58 AM
Agreed, a HF one & trim the jaws slightly as/if needed for a dead on grip/fit & as said put some tension on with that & hit both sides at the same time with good sized hammers. Any issue as was said I pull the whole assy & get it on the bench for a less damaging breakdown. Hammers are always my last resort but are needed on occaision
