3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? #2199271
11/20/16 05:42 AM
11/20/16 05:42 AM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
My teenager is building a 64 sweptline. He put a 318 in it with a 90 3.9 v6 bell and a 833OD 4 speed. After bolting the starter in...we tapped it over and the starter just freewheeled. Pulled the dust shield off and realized there is like a 1/2" gap between the side of the starter gear and the flywheel teeth. Wish I would have checked that before he bolted it in the truck!
When we bought the bell, I thought all smallblocks were 130 tooth flywheels. I guess not. frown After searching posts...it appears he needs a 143 tooth internally balanced flywheel. I'm having trouble finding one except the $500 centerforce one...plus, I would like it to accept a 10.5 clutch since he already bought/installed a brand new one (on the 130tooth flywheel we have). Does such a thing exist? Anyone know where to find one?
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199449
11/20/16 05:12 PM
11/20/16 05:12 PM
Central Valley, CA.
Central Valley, CA.
I found this LUK flywheel: LFW106
https://www.summitracing.com/parts/luk-lfw106/applications/
http://schaeffler.opticatonline.com/part/bbzh-luk-lfw106?ctx_bv=1776&ctx_region=usa&ctx=1
I "think" its a 143 tooth..and pictures show it drilled for 2 clutch patterns...but I cant confirm. But I guess that could be a 11" and 12" pattern. Can anyone even confirm if this is a 143 tooth flywheel that takes a 11" clutch?
And confirm a LUK-05-038 is an 11" clutch?
https://www.summitracing.com/parts/luk-05-038
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199461
11/20/16 05:58 PM
11/20/16 05:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Buy a flywheel for a 90 V6, it'll bolt onto the 318, RockAuto has them for about $65, OEM replacement.
Don't be the exception.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199585
11/20/16 09:42 PM
11/20/16 09:42 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Bolts up sure. Is the balance right?
Angry white pureblood male
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199600
11/20/16 10:05 PM
11/20/16 10:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, both the 3.9 and the 318 are neutral balance.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Supercuda] #2199664
11/20/16 11:57 PM
11/20/16 11:57 PM
Central Valley, CA.
Central Valley, CA.
Thanks for the reply. I looked at that $60 one on rockauto and looked up the specs....it is a 130 tooth flywheel (Which is what I have and doesn't work). Looks like that flywheel is for 90 V6 with a 5 speed. Looks like there is also 4 speed option that year (could that be a 833 OD? or maybe a truck 4 spd?) which uses the 143 tooth flywheel.
I have confirmed the 3.9 V6 and the 5.2's are all internal balance. Only the 360's were external balance.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199678
11/21/16 12:23 AM
11/21/16 12:23 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Side question for you:
The V6 bell has the 5.125" input bearing size?
Mo' Farts
Moderated by "tbagger".
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199689
11/21/16 12:41 AM
11/21/16 12:41 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure what you looked at, did you look at a Dak or a Ram? I assumed Dak.
RA shows the Luk flywheel you posted for about $74 if you look under the 90 Ram listing.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Supercuda] #2199698
11/21/16 12:53 AM
11/21/16 12:53 AM
Central Valley, CA.
Central Valley, CA.
I looked under d150 ram...i saw the LUK there, good deal....but I don't think it's drilled for my 10.5" clutch. So, I'll probably need a clutch setup too. Just would like to order it all at once, or better yet use my existing clutch.
Yes, the V6 bell takes the big 5.125 retainer.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: Quicksilver440] #2199997
11/21/16 03:32 PM
11/21/16 03:32 PM
dogdays Offline
dogdays  Offline
143 tooth neutral balanced flywheels.
http://www.rockauto.com/en/catalog/dodge,1992,d250+pickup,5.2l+v8,1086140,transmission-manual,flywheel,5348?a=Referer+www.bing.com+URL+%2F
There are also billet flywheels from places like 440Source for not too much more, and a billet flywheel is safer.
The flywheel will be drilled for an 11" pressure plate, either diaphragm or Borg & Beck, they use the same bolt pattern. This bolt pattern will also fit a 12" pressure plate.
Good news for you is that the 11" pressure plate will work with a 10.5" disk, there'll just be around 1/4" of pressure plate that doesn't get used.
OR, you could have a machine shop drill the flywheel for the 10.5" pressure plate. I did something like this and it cost $35.00 Holes are drilled all the way through and threaded, then counterbored so no threads pull up and keep the pressure plate from seating.
R.
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch? [Re: dogdays] #2200684
11/22/16 06:42 PM
11/22/16 06:42 PM
Central Valley, CA.
Central Valley, CA.
Thanks guys...I went ahead and ordered a new flywheel and clutch setup and will just sell my current/ clutch setup to recoup most of it. It's easier that way...
