3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch?
#2199271
11/20/16 05:42 AM
11/20/16 05:42 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
My teenager is building a 64 sweptline. He put a 318 in it with a 90 3.9 v6 bell and a 833OD 4 speed. After bolting the starter in...we tapped it over and the starter just freewheeled. Pulled the dust shield off and realized there is like a 1/2" gap between the side of the starter gear and the flywheel teeth. Wish I would have checked that before he bolted it in the truck! When we bought the bell, I thought all smallblocks were 130 tooth flywheels. I guess not. After searching posts...it appears he needs a 143 tooth internally balanced flywheel. I'm having trouble finding one except the $500 centerforce one...plus, I would like it to accept a 10.5 clutch since he already bought/installed a brand new one (on the 130tooth flywheel we have). Does such a thing exist? Anyone know where to find one?
Re: 3.9 v6 bell on 318 & 833OD..flywheel question..10.5 clutch?
[Re: Quicksilver440]
#2199461
11/20/16 05:58 PM
11/20/16 05:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Buy a flywheel for a 90 V6, it'll bolt onto the 318, RockAuto has them for about $65, OEM replacement.
#2199585
11/20/16 09:42 PM
11/20/16 09:42 PM
Posts: 5,777 ohio
ruderunner
ohio
Bolts up sure. Is the balance right?
Angry white pureblood male
#2199600
11/20/16 10:05 PM
11/20/16 10:05 PM
Supercuda
About to go away
About to go away
up yours
Yes, both the 3.9 and the 318 are neutral balance.
#2199678
11/21/16 12:23 AM
11/21/16 12:23 AM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Side question for you:
The V6 bell has the 5.125" input bearing size?
Mo' Farts
Moderated by "tbagger".
#2199689
11/21/16 12:41 AM
11/21/16 12:41 AM
Supercuda
About to go away
About to go away
up yours
Not sure what you looked at, did you look at a Dak or a Ram? I assumed Dak.
RA shows the Luk flywheel you posted for about $74 if you look under the 90 Ram listing.
[Re: Supercuda]
#2199698
11/21/16 12:53 AM
11/21/16 12:53 AM
Quicksilver440
Central Valley, CA.
I looked under d150 ram...i saw the LUK there, good deal....but I don't think it's drilled for my 10.5" clutch. So, I'll probably need a clutch setup too. Just would like to order it all at once, or better yet use my existing clutch.
Yes, the V6 bell takes the big 5.125 retainer.
#2199997
11/21/16 03:32 PM
11/21/16 03:32 PM
dogdays
143 tooth neutral balanced flywheels.
http://www.rockauto.com/en/catalog/dodge,1992,d250+pickup,5.2l+v8,1086140,transmission-manual,flywheel,5348?a=Referer+www.bing.com+URL+%2F
There are also billet flywheels from places like 440Source for not too much more, and a billet flywheel is safer.
The flywheel will be drilled for an 11" pressure plate, either diaphragm or Borg & Beck, they use the same bolt pattern. This bolt pattern will also fit a 12" pressure plate.
Good news for you is that the 11" pressure plate will work with a 10.5" disk, there'll just be around 1/4" of pressure plate that doesn't get used.
OR, you could have a machine shop drill the flywheel for the 10.5" pressure plate. I did something like this and it cost $35.00 Holes are drilled all the way through and threaded, then counterbored so no threads pull up and keep the pressure plate from seating.
R.
