Coolant for track #2198403
11/18/16 07:51 AM
11/18/16 07:51 AM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Is there any coolant that is track legal besides water? I hate to have drain and put antifreeze in every winter.
Re: Coolant for track [Re: 68dodge] #2198428
11/18/16 11:34 AM
11/18/16 11:34 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
not out in these parts....
Re: Coolant for track [Re: J_BODY] #2198479
11/18/16 01:43 PM
11/18/16 01:43 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
For your one day of winter? Don't think you need antifreeze!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Coolant for track [Re: 68dodge] #2198491
11/18/16 02:18 PM
11/18/16 02:18 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Without Data, you’re just another guy with an opinion.
Re: Coolant for track [Re: sr4440] #2198494
11/18/16 02:23 PM
11/18/16 02:23 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Our track has a HUGE street car turnout on grudge nights. Being in Kansas, I can tell you every single car has coolant in it. They do check for an overflow, but it always has green Prestone in it and they never say a thing.
How many tracks actually police this?
'63 Dodge 330
11.19 @ 121 mph
Re: Coolant for track [Re: sr4440] #2198502
11/18/16 02:50 PM
11/18/16 02:50 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Not legal for track, just waterless and is more slippery and would bet just as hard to clean up.
Re: Coolant for track [Re: GY3] #2198504
11/18/16 02:53 PM
11/18/16 02:53 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Aren't you as racer supposed to police yourself so you don't cause unnecessary clean ups and danger to your fellow racer so he doesn't crash in your slippery coolant. I though the rules where for our own Saftey and that of our fellow racers.
Re: Coolant for track [Re: GY3] #2198505
11/18/16 02:57 PM
11/18/16 02:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Very few CHECK for anti-freeze. This is just one of those "unwritten rules". Been several times I know of that after a guy dumps a couple gallons of anti-freeze on the starting line or sprays it the length of the track......that he is invited to NEVER come back to that track
Re: Coolant for track [Re: Monte_Smith] #2198521
11/18/16 03:29 PM
11/18/16 03:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agree and hardly any do.
Back in '06 when I was running with F.A.S.T. we were at Lebanon Valley and I was on the return road when one of the Stock guys goes past me on the track and I can see something spraying on the ground under his car as he goes by. I was near half track, stopped my car, jumped out, ran over to the wall and was waving to see if I could get someones attention in the tower or starting line as Tom Cannon and Ralph Barbagello were staging , they saw me but only said something about moving back from the wall ... Tom and Ralph launch and as Ralph goes past Tom about 100 feet out Tom's Challenger takes a hard RIGHT and spins behind Ralph just missing him, does a 360 and just taps the wall ... luckily the damage was minimal ... at that point they decide to check the track and clean up the Coolant that was sprayed all the way to the end of the track from just past the starting line ... the racers bypass hose of his 340 had come off as he launched ...
Draining out the water is not as big a deal as it is fixing your car after you wreck it ...
Re: Coolant for track [Re: JohnRR] #2198528
11/18/16 03:42 PM
11/18/16 03:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don't know why guys think this is such a project to add and remove anti-freeze ONCE a year. These are probably the same guys that be-itch the loudest waiting for track clean-ups. Cheese and rice.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Coolant for track [Re: 68dodge] #2198531
11/18/16 03:48 PM
11/18/16 03:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not trying to hijack this thread but what is best product to add to the water to keep corrosion to a minimum?
Re: Coolant for track [Re: pittsburghracer] #2198621
11/18/16 07:44 PM
11/18/16 07:44 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Wow! Did not realize this would upset you. Just wanted to know if anyone has seen any new products that are legal to use.
Re: Coolant for track [Re: 68dodge] #2198623
11/18/16 07:55 PM
11/18/16 07:55 PM
PA.
"Little"John
"Little"John
PA.
Hey it is what it is and its really not hard to do. I make things on my car that I hate doing easier so its not hard next time. They sell screw in block fitting that go right in the factory block drain plugs and most radiators have drain plugs. Drain a gallon of water and add a gallon of antifreeze. Catch it next year and reuse it. It may save YOU from wrecking or someone else. Prestone also offers waterpump lube and anti-rust to use during the summer. I don't honestly know if its safer than antifreeze as I use plain water and change it out often during the Summer.
http://prestone.com/enmx/node/1428
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Coolant for track [Re: sr4440] #2198701
11/18/16 10:53 PM
11/18/16 10:53 PM
jersey
Spaceman Spiff Offline
jersey
I had a friend try that in his turbo car.
sure, it did bring help to bring down the coolant temp some....
but his OIL temp went UP 20*....
i guess the heat has to go somewhere..
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Coolant for track [Re: 68dodge] #2198837
11/19/16 09:29 AM
11/19/16 09:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
As said its more of an unwritten rule. But I know that at the T & T I was at a few weeks ago atleast half the cars there were street cars and I am sure 99.9% had anti-freeze in them. Sure the track dont want coolant in them but I dont think they will turn half the cars away and loose all that money or take the time police whats in each cars rad. Course they should as they tell me its a bigger pain to clean a coolant spill then an oil spill. Ron
Re: Coolant for track [Re: 383man] #2198895
11/19/16 12:53 PM
11/19/16 12:53 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I switched to water only and now electrolysis is killing radiators, I was thinking about using Evans, but I'm bummed to read it's just as slippery as antifreeze.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Coolant for track [Re: 68dodge] #2203066
11/26/16 11:35 PM
11/26/16 11:35 PM
Queensland Australia
moparmacka Offline
moparmacka  Offline
Penrite 10 tenths. I almost positive the have a warehouse in the US. Great product, non glycol based inhibitor approved by all Australian Motorsport sancioning bodies.
Check out - penrite.com.au and look under the racing heading, then scroll down to almost the bottom of the page.
Re: Coolant for track [Re: 68dodge] #2203215
11/27/16 08:57 AM
11/27/16 08:57 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
http://www.lubegard.com/~/C-201/Kool-It+Supreme+Coolant+Treatment
