Re: Coolant for track
[Re: J_BODY]
#2198479
11/18/16 01:43 PM
11/18/16 01:43 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
not out in these parts.... For your one day of winter? Don't think you need antifreeze!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: sr4440]
#2198494
11/18/16 02:23 PM
11/18/16 02:23 PM
Posts: 4,669 Wichita
GY3
Wichita
Our track has a HUGE street car turnout on grudge nights. Being in Kansas, I can tell you every single car has coolant in it. They do check for an overflow, but it always has green Prestone in it and they never say a thing.
How many tracks actually police this?
[Re: sr4440]
#2198502
11/18/16 02:50 PM
11/18/16 02:50 PM
1967dartgt
Hilltown Pa
Not legal for track, just waterless and is more slippery and would bet just as hard to clean up.
[Re: GY3]
#2198504
11/18/16 02:53 PM
11/18/16 02:53 PM
1967dartgt
Hilltown Pa
How many tracks actually police this? Aren't you as racer supposed to police yourself so you don't cause unnecessary clean ups and danger to your fellow racer so he doesn't crash in your slippery coolant. I though the rules where for our own Saftey and that of our fellow racers.
[Re: GY3]
#2198505
11/18/16 02:57 PM
11/18/16 02:57 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
How many tracks actually police this? Very few CHECK for anti-freeze. This is just one of those "unwritten rules". Been several times I know of that after a guy dumps a couple gallons of anti-freeze on the starting line or sprays it the length of the track......that he is invited to NEVER come back to that track
[Re: Monte_Smith]
#2198521
11/18/16 03:29 PM
11/18/16 03:29 PM
Posts: 74,974 U.S.S.A.
JohnRR
U.S.S.A.
How many tracks actually police this? Very few CHECK for anti-freeze. This is just one of those "unwritten rules". Been several times I know of that after a guy dumps a couple gallons of anti-freeze on the starting line or sprays it the length of the track......that he is invited to NEVER come back to that track Agree and hardly any do. Back in '06 when I was running with F.A.S.T. we were at Lebanon Valley and I was on the return road when one of the Stock guys goes past me on the track and I can see something spraying on the ground under his car as he goes by. I was near half track, stopped my car, jumped out, ran over to the wall and was waving to see if I could get someones attention in the tower or starting line as Tom Cannon and Ralph Barbagello were staging , they saw me but only said something about moving back from the wall ... Tom and Ralph launch and as Ralph goes past Tom about 100 feet out Tom's Challenger takes a hard RIGHT and spins behind Ralph just missing him, does a 360 and just taps the wall ... luckily the damage was minimal ... at that point they decide to check the track and clean up the Coolant that was sprayed all the way to the end of the track from just past the starting line ... the racers bypass hose of his 340 had come off as he launched ... Draining out the water is not as big a deal as it is fixing your car after you wreck it ...
[Re: JohnRR]
#2198528
11/18/16 03:42 PM
11/18/16 03:42 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't know why guys think this is such a project to add and remove anti-freeze ONCE a year. These are probably the same guys that be-itch the loudest waiting for track clean-ups. Cheese and rice.
[Re: pittsburghracer]
#2198621
11/18/16 07:44 PM
11/18/16 07:44 PM
Posts: 516 ,Pa.
68dodge
,Pa.
I don't know why guys think this is such a project to add and remove anti-freeze ONCE a year. These are probably the same guys that be-itch the loudest waiting for track clean-ups. Cheese and rice. Wow! Did not realize this would upset you. Just wanted to know if anyone has seen any new products that are legal to use.
[Re: 68dodge]
#2198623
11/18/16 07:55 PM
11/18/16 07:55 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't know why guys think this is such a project to add and remove anti-freeze ONCE a year. These are probably the same guys that be-itch the loudest waiting for track clean-ups. Cheese and rice. Wow! Did not realize this would upset you. Just wanted to know if anyone has seen any new products that are legal to use. Hey it is what it is and its really not hard to do. I make things on my car that I hate doing easier so its not hard next time. They sell screw in block fitting that go right in the factory block drain plugs and most radiators have drain plugs. Drain a gallon of water and add a gallon of antifreeze. Catch it next year and reuse it. It may save YOU from wrecking or someone else. Prestone also offers waterpump lube and anti-rust to use during the summer. I don't honestly know if its safer than antifreeze as I use plain water and change it out often during the Summer. http://prestone.com/enmx/node/1428
[Re: sr4440]
#2198701
11/18/16 10:53 PM
11/18/16 10:53 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I had a friend try that in his turbo car. sure, it did bring help to bring down the coolant temp some.... but his OIL temp went UP 20*.... i guess the heat has to go somewhere..
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: 383man]
#2198895
11/19/16 12:53 PM
11/19/16 12:53 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I switched to water only and now electrolysis is killing radiators, I was thinking about using Evans, but I'm bummed to read it's just as slippery as antifreeze.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
