NAG1 into an A body?? #2181569
10/24/16 05:17 PM
10/24/16 05:17 PM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
Just like it says. Will a NAG1 out of an 06 Charger fit the trans tunnel of an A-body?? Just figured if it did it would be nice to have an overdrive with the 3.91 gears. Thanks!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: NAG1 into an A body?? [Re: Prodart440] #2181577
10/24/16 05:32 PM
10/24/16 05:32 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
How do you plan on adapting the electronics?
Re: NAG1 into an A body?? [Re: stumpy] #2181587
10/24/16 05:44 PM
10/24/16 05:44 PM
Avondale AZ
Avondale AZ
I have a complete 06 Charger 5.7 that I will take everything from. So it'll have the Hemi/NAG1 with the factory computer.
Aaron
68 Coronet 440
Re: NAG1 into an A body?? [Re: Prodart440] #2181636
10/24/16 07:03 PM
10/24/16 07:03 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
No first hand experience but won't the computer be looking for dozens of other inputs besides the engine and trans causing all kinds of mysterious errors?
Re: NAG1 into an A body?? [Re: Prodart440] #2181640
10/24/16 07:12 PM
10/24/16 07:12 PM
Avondale AZ
Avondale AZ
Maybe, what else would it be looking for??
Aaron
68 Coronet 440
Re: NAG1 into an A body?? [Re: Prodart440] #2181710
10/24/16 08:38 PM
10/24/16 08:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That you ought to find out before you spend nickle one on this swap.
It's a ton of stuff.
https://board.moparts.org/ubbthreads/ubbt...found-this.html
Don't be the exception.
Re: NAG1 into an A body?? [Re: Prodart440] #2181733
10/24/16 09:02 PM
10/24/16 09:02 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
NAG1 requires a speed signal from the ABS sensors to run the stock computers. Hotwire Auto Electric sells a tone ring/sensor setup, and re-flashes your stock PCM, TCM, ABS and FCM to work with it. Give them a call and ask for Chris Squier. He'll be able to answer all of your questions. I use his system in my 5.7 Hemi/NAG1 Mirada, and it works great.
Re: NAG1 into an A body?? [Re: Prodart440] #2182017
10/25/16 10:32 AM
10/25/16 10:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No. The NAG1 is gigantic compared to a rinky dink 904 or 727. The only automatic overdrives that I'm aware of that'll fit under your tunnel without chopping the torsion bar crossmember and/or the tunnel will be the GM 200-4R or 700-R4.
Re: NAG1 into an A body?? [Re: DaytonaTurbo] #2182097
10/25/16 12:50 PM
10/25/16 12:50 PM
Avondale AZ
Avondale AZ
This was my main concern. If it won't physically fit, I won't be putting it in. I guess I will use a 727.
Aaron
68 Coronet 440
Re: NAG1 into an A body?? [Re: Prodart440] #2182101
10/25/16 12:59 PM
10/25/16 12:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why not just cut the tunnel and make it fit ?
Re: NAG1 into an A body?? [Re: JohnRR] #2182130
10/25/16 01:36 PM
10/25/16 01:36 PM
dogdays Offline
dogdays  Offline
That actually makes sense, there is going to be a lot of re-engineering on the car and it isn't a collector's item anyway. Build it the way YOU want it.
So, does anyone make a replacement K-member that uses coilovers for the A body?
R.
Re: NAG1 into an A body?? [Re: dogdays] #2182149
10/25/16 02:04 PM
10/25/16 02:04 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
AlterKation will work just fine! up
JB Rhinehart, Realist
A-Body's RULE!
Re: NAG1 into an A body?? [Re: Prodart440] #2182153
10/25/16 02:07 PM
10/25/16 02:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What about a gear venders?
Re: NAG1 into an A body?? [Re: Prodart440] #2182168
10/25/16 02:28 PM
10/25/16 02:28 PM
Grand Prairie,Texas
Grand Prairie,Texas
PATC gives the complete instructions on how to make a three wire A518od trans work in place of a 727.It is a good swap.
Re: NAG1 into an A body?? [Re: dogdays] #2182212
10/25/16 03:04 PM
10/25/16 03:04 PM
Manitoba, Canada
Manitoba, Canada
R.
Or you could cut off the front clip, lay down new frame rails and do a complete mustang ii type front suspension. I bet you'd shed a few pounds.
He doesn't want to cut and the 518 won't fit under a stock torsion bar crossmember.
Re: NAG1 into an A body?? [Re: Prodart440] #2182239
10/25/16 03:44 PM
10/25/16 03:44 PM
Grand Prairie,Texas
Grand Prairie,Texas
If he does cut here is an idea of what needs to be done. http://www.moparts.org/Tech/Archive/auto/28.html
Re: NAG1 into an A body?? [Re: Prodart440] #2182401
10/25/16 07:06 PM
10/25/16 07:06 PM
Joe12459 Offline
Joe12459  Offline
I used the AlterKtion setup in mine. I ordered it without the motor mounts welded in, so I could position the drivetrain where I wanted it. By mounting the engine approximately five inches forward of where a stock small block would mount, I was able to install the NAG1 with NO MODIFICATION to tunnel or crossmember. Of course this was a J body, so it might not work that well in your car. I had to use a rear sump pan, and truck passenger exhaust manifold, but otherwise all of the Charger stuff went in.
Re: NAG1 into an A body?? [Re: Joe12459] #2182411
10/25/16 07:16 PM
10/25/16 07:16 PM
Avondale AZ
Avondale AZ
How did you end up controlling the NAG1?? Did you use a factory computer?
Aaron
68 Coronet 440
Re: NAG1 into an A body?? [Re: Joe12459] #2182415
10/25/16 07:20 PM
10/25/16 07:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How did that affect the handling by shifting all that weight forward ?
Re: NAG1 into an A body?? [Re: JohnRR] #2182419
10/25/16 07:22 PM
10/25/16 07:22 PM
Joe12459 Offline
Joe12459  Offline
It actually handles really well. I don't think those few inches made much of a difference, as the weight is still mostly over the center of the crossmember.
