NAG1 into an A body??
#2181569
10/24/16 05:17 PM
10/24/16 05:17 PM
Posts: 851 Avondale AZ
Prodart440
Avondale AZ
Just like it says. Will a NAG1 out of an 06 Charger fit the trans tunnel of an A-body?? Just figured if it did it would be nice to have an overdrive with the 3.91 gears. Thanks!!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: NAG1 into an A body??
[Re: stumpy]
#2181587
10/24/16 05:44 PM
10/24/16 05:44 PM
Prodart440
Avondale AZ
I have a complete 06 Charger 5.7 that I will take everything from. So it'll have the Hemi/NAG1 with the factory computer.
Aaron
[Re: Prodart440]
#2181636
10/24/16 07:03 PM
10/24/16 07:03 PM
Posts: 4,769 Moved to N.E. Tennessee
GomangoCuda
No first hand experience but won't the computer be looking for dozens of other inputs besides the engine and trans causing all kinds of mysterious errors?
[Re: Prodart440]
#2181640
10/24/16 07:12 PM
10/24/16 07:12 PM
Prodart440
Avondale AZ
Maybe, what else would it be looking for??
Aaron
[Re: Prodart440]
#2181710
10/24/16 08:38 PM
10/24/16 08:38 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Maybe, what else would it be looking for?? That you ought to find out before you spend nickle one on this swap. It's a ton of stuff. https://board.moparts.org/ubbthreads/ubbt...found-this.html
[Re: Prodart440]
#2182017
10/25/16 10:32 AM
10/25/16 10:32 AM
DaytonaTurbo
Manitoba, Canada
Will a NAG1 out of an 06 Charger fit the trans tunnel of an A-body?? No. The NAG1 is gigantic compared to a rinky dink 904 or 727. The only automatic overdrives that I'm aware of that'll fit under your tunnel without chopping the torsion bar crossmember and/or the tunnel will be the GM 200-4R or 700-R4.
[Re: DaytonaTurbo]
#2182097
10/25/16 12:50 PM
10/25/16 12:50 PM
Prodart440
Avondale AZ
Will a NAG1 out of an 06 Charger fit the trans tunnel of an A-body?? No. The NAG1 is gigantic compared to a rinky dink 904 or 727. The only automatic overdrives that I'm aware of that'll fit under your tunnel without chopping the torsion bar crossmember and/or the tunnel will be the GM 200-4R or 700-R4. This was my main concern. If it won't physically fit, I won't be putting it in. I guess I will use a 727.
Aaron
[Re: Prodart440]
#2182101
10/25/16 12:59 PM
10/25/16 12:59 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
Will a NAG1 out of an 06 Charger fit the trans tunnel of an A-body?? No. The NAG1 is gigantic compared to a rinky dink 904 or 727. The only automatic overdrives that I'm aware of that'll fit under your tunnel without chopping the torsion bar crossmember and/or the tunnel will be the GM 200-4R or 700-R4. This was my main concern. If it won't physically fit, I won't be putting it in. I guess I will use a 727. Why not just cut the tunnel and make it fit ?
[Re: dogdays]
#2182212
10/25/16 03:04 PM
10/25/16 03:04 PM
DaytonaTurbo
Manitoba, Canada
So, does anyone make a replacement K-member that uses coilovers for the A body?
R.
Or you could cut off the front clip, lay down new frame rails and do a complete mustang ii type front suspension. I bet you'd shed a few pounds. PATC gives the complete instructions on how to make a three wire A518od trans work in place of a 727.It is a good swap. He doesn't want to cut and the 518 won't fit under a stock torsion bar crossmember.
[Re: Joe12459]
#2182411
10/25/16 07:16 PM
10/25/16 07:16 PM
Prodart440
Avondale AZ
I used the AlterKtion setup in mine. I ordered it without the motor mounts welded in, so I could position the drivetrain where I wanted it. By mounting the engine approximately five inches forward of where a stock small block would mount, I was able to install the NAG1 with NO MODIFICATION to tunnel or crossmember. Of course this was a J body, so it might not work that well in your car. I had to use a rear sump pan, and truck passenger exhaust manifold, but otherwise all of the Charger stuff went in. How did you end up controlling the NAG1?? Did you use a factory computer?
Aaron
[Re: Joe12459]
#2182415
10/25/16 07:20 PM
10/25/16 07:20 PM
JohnRR
I used the AlterKtion setup in mine. I ordered it without the motor mounts welded in, so I could position the drivetrain where I wanted it. By mounting the engine approximately five inches forward of where a stock small block would mount, I was able to install the NAG1 with NO MODIFICATION to tunnel or crossmember. Of course this was a J body, so it might not work that well in your car. I had to use a rear sump pan, and truck passenger exhaust manifold, but otherwise all of the Charger stuff went in. How did that affect the handling by shifting all that weight forward ?
