whats a good head light up grade #2179253
10/20/16 05:23 PM
10/20/16 05:23 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
for a 90 ramcharger ? or should i just mount a led light bar to the bumper
Re: whats a good head light up grade [Re: theraif] #2179264
10/20/16 05:44 PM
10/20/16 05:44 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
You could try these linky from Amazon. I have a pair but haven't installed them as yet. Maybe never since we took her Ramcharger out of daily service.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: whats a good head light up grade [Re: theraif] #2179269
10/20/16 06:04 PM
10/20/16 06:04 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
I put the round conversion bulbs in my 73 that use the removable halogen bulbs, and ran them off relays as well They make them for the square lights as well, might give them a try. The ones on my truck made a big improvement with some higher watt bulbs.
Re: whats a good head light up grade [Re: lunacy] #2179325
10/20/16 08:15 PM
10/20/16 08:15 PM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
hella H6054 sealed beam conversion
hella sealed beam conversion and headlight relay upgrade.
It's the most dependable way to upgrade lights, plus take a big load off factory switches and wiring
I would also add a note that says stay away from cheaper fancy looking conversions.
They are just that cheap fancy "looking", not functional. And don't be one of the A-holes that runs HID bulbs in a halogen based housing, it just plain sucks for performance and jacks off every oncoming car.
Re: whats a good head light up grade [Re: theraif] #2179357
10/20/16 09:02 PM
10/20/16 09:02 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I did the conversion as well with the relays,nice and bright now.
Re: whats a good head light up grade [Re: polaris400cc] #2179748
10/21/16 02:34 PM
10/21/16 02:34 PM
Guitar Jones Offline
One of the best upgrades done to my 92.
Re: whats a good head light up grade [Re: theraif] #2179983
10/21/16 10:09 PM
10/21/16 10:09 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Another vote for relays. Don't bother with a kit. Get some used relays from the junkyard, a few crimp on terminals and a couple feet of wire and inline fuse holders. Cheap easy and very effective.
Angry white pureblood male
Re: whats a good head light up grade [Re: theraif] #2180345
10/22/16 02:54 PM
10/22/16 02:54 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
thanks
Re: whats a good head light up grade [Re: ruderunner] #2180743
10/23/16 10:19 AM
10/23/16 10:19 AM
I bought the kit from LMC, it's not expensive and super easy to install. I was going to make my own but the whole thing saved a lot of time and except for drilling a couple holes to mount the relays and two ground wires it was totally plug and play.
Re: whats a good head light up grade [Re: theraif] #2183003
10/26/16 02:51 PM
10/26/16 02:51 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I agree on the relays. Before installing relays on my 93 ram, the headlights were dangerously dim. I measured 9 volts at the headlight, with the engine running. After installing relays, it had full alternator voltage to the bulbs, about 13.8V. That plus a pair of $5 Wagner H6054 halogen sealed beams, and it has incredibly bright lights! One caveat: at 9 volts, the sealed beams would last just about forever. Not so when you zap them with 13-14 volts. It seems that I only get about 2 years out of a bulb. But for 5 bucks, who cares?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: whats a good head light up grade [Re: theraif] #2185145
10/29/16 09:03 AM
10/29/16 09:03 AM
Groveland, MA
SteveS Offline
SteveS  Offline
Groveland, MA
The Hella conversions are amazing.
Steve
Someday I'll have another C-body.
