Cam from 426 HEMI #2179246
10/20/16 05:12 PM
10/20/16 05:12 PM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
I chucked this cam up in my lathe to measure the lobes. No cam card or idea who the mfg is.
Anybody have an idea who the mfg might be?
Re: Cam from 426 HEMI [Re: Tempest] #2179275
10/20/16 06:23 PM
10/20/16 06:23 PM
an8sec70cuda Offline
The numbers stamped on the ends of the cam are what you need to ID the cam. The others are just casting markings...will be the same for many cams since a lot of the cores come from the same place.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cam from 426 HEMI [Re: Tempest] #2179276
10/20/16 06:28 PM
10/20/16 06:28 PM
Tempest Offline OP
Tempest  Offline OP
I have searched that number over and over and not found a thing.
Re: Cam from 426 HEMI [Re: Tempest] #2179280
10/20/16 06:44 PM
10/20/16 06:44 PM
P
Porter67 Offline
Porter67  Offline
P
Didnt DC use different color paint dots like at the top of you pic?
Re: Cam from 426 HEMI [Re: Tempest] #2179289
10/20/16 06:57 PM
10/20/16 06:57 PM
Tempest Offline OP
Tempest  Offline OP
I checked all the old DC part numbers. I also checked, Crane, Comp, Crower, Erson, Isky, Howards, Schneider, Lunati, Melling. I cannot come up with a number for this thing?
Re: Cam from 426 HEMI [Re: Tempest] #2179293
10/20/16 07:00 PM
10/20/16 07:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As stated, the numbers you're looking at are for the cam blank, before it's ground to a particular profile. If there are no numbers stamped in journal ends, it's likely a factory cam.
Re: Cam from 426 HEMI [Re: Tempest] #2179299
10/20/16 07:13 PM
10/20/16 07:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
How many differences from a 440 cam to hemi. Are all the journals different?
Re: Cam from 426 HEMI [Re: FastmOp] #2179318
10/20/16 07:55 PM
10/20/16 07:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've been told that he lifter angle in the blocks are different, the wedge cams have the exhaust lobes first and the Hemiroid motors have the intake lobe first, not sure about other differences confused
Re: Cam from 426 HEMI [Re: Tempest] #2179320
10/20/16 08:02 PM
10/20/16 08:02 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Hemis and wedges use different lobe order as Cab pointed out. No swapping allowed. Lifter angles are the same.
Re: Cam from 426 HEMI [Re: Tempest] #2179622
10/21/16 10:02 AM
10/21/16 10:02 AM
warren, mich.
dwayne welder Offline
warren, mich.
Take it to someone who has a Cam Doctor and get the profile information!! That should help you find out what kind of camshaft you have!!! Good luck
Re: Cam from 426 HEMI [Re: dwayne welder] #2179697
10/21/16 01:11 PM
10/21/16 01:11 PM
Tempest Offline OP
Tempest  Offline OP
I did that on my lathe with dial indicator and it's about dead nuts for a factory HEMI grind. Was basically trying to find out if it was stock or a aftermarket replacement. Given the fact none of the aftermarket mfg's part #'s are close, maybe it is a factory cam?
Re: Cam from 426 HEMI [Re: Tempest] #3079792
09/22/22 10:33 PM
09/22/22 10:33 PM
New York
B Body Fan1 Offline
B Body Fan1  Offline
New York
Great topic guys- Found this on my 426 Hemi camshaft while boroscoping to find try to identify the cam. Some research about CWC indicates they are a casting company for many years. I suspect it is the original camshaft as well but I’m still not too sure what the specs are. Tempest- did you record the specs on your cam? My motor is a warranty unit dated 1-19-70
Re: Cam from 426 HEMI [Re: B Body Fan1] #3079797
09/22/22 10:43 PM
09/22/22 10:43 PM
1970 and 1971 Street Hemi motors came with hydraulic lifters stock, not solids like they had from 1966 to 1969 shruggy
Re: Cam from 426 HEMI [Re: Cab_Burge] #3080084
09/23/22 06:58 PM
09/23/22 06:58 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think CWC cast the 1964 Hemi heads
2011 Drag Pak Challenger
Re: Cam from 426 HEMI [Re: rickseeman] #3080094
09/23/22 07:17 PM
09/23/22 07:17 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
And they cast the Street Hemi heads
