Re: Cam from 426 HEMI
[Re: Tempest]
#2179275
10/20/16 06:23 PM
10/20/16 06:23 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
The numbers stamped on the ends of the cam are what you need to ID the cam. The others are just casting markings...will be the same for many cams since a lot of the cores come from the same place.
[Re: Tempest]
#2179289
10/20/16 06:57 PM
10/20/16 06:57 PM
Posts: 596 Nashville, Tennessee
Tempest
I checked all the old DC part numbers. I also checked, Crane, Comp, Crower, Erson, Isky, Howards, Schneider, Lunati, Melling. I cannot come up with a number for this thing?
[Re: Tempest]
#2179293
10/20/16 07:00 PM
10/20/16 07:00 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
As stated, the numbers you're looking at are for the cam blank, before it's ground to a particular profile. If there are no numbers stamped in journal ends, it's likely a factory cam.
[Re: dwayne welder]
#2179697
10/21/16 01:11 PM
10/21/16 01:11 PM
Tempest
Take it to someone who has a Cam Doctor and get the profile information!! That should help you find out what kind of camshaft you have!!! Good luck I did that on my lathe with dial indicator and it's about dead nuts for a factory HEMI grind. Was basically trying to find out if it was stock or a aftermarket replacement. Given the fact none of the aftermarket mfg's part #'s are close, maybe it is a factory cam?
