Carburetor spacers #2176007
10/16/16 01:52 PM
10/16/16 01:52 PM
,Pa.
68dodge Offline OP
68dodge  Offline OP
,Pa.
Anyone do any testing with carb spacers 1" or 2". Wanted to know if it's worth trying down the track.
Re: Carburetor spacers [Re: 68dodge] #2176011
10/16/16 01:55 PM
10/16/16 01:55 PM
Washington
skrews Offline
skrews  Offline
Washington
popcorn
Re: Carburetor spacers [Re: 68dodge] #2176081
10/16/16 03:22 PM
10/16/16 03:22 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've used both open and four hole spacers in both hieghts, try it up
let us know how much faster your car goes with each one scope
Re: Carburetor spacers [Re: 68dodge] #2176089
10/16/16 03:35 PM
10/16/16 03:35 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've done it on the dyno, and on that particular engine various combinations make some (8-10HP/TQ) difference.
Tried 1" open, 1" 4-hole, 2" open, 2" 4-hole, swapping around between 1", 2", combining the two 1", etc on a 358" SB drag-race motor.
Re: Carburetor spacers [Re: 68dodge] #2176167
10/16/16 05:26 PM
10/16/16 05:26 PM
AndyF Offline
AndyF  Offline
Almost all combinations will pick up at least a little bit of power with a merge type spacer. 1", 1.5 or 2" if you have the room. Wilson has the best selection and the lightest spacers but they are also very expensive.
Re: Carburetor spacers [Re: 68dodge] #2176259
10/16/16 07:20 PM
10/16/16 07:20 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
both of my buddies picked up 15 hp on the dyno with those fancy 2" tapered spacers. One has the Wilson the other is HVH or something like that. One is BBM and one is SBC.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Carburetor spacers [Re: 68dodge] #2176273
10/16/16 07:43 PM
10/16/16 07:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 434 small block made 13 more hp with a 1" super sucker on the dyno.
Re: Carburetor spacers [Re: 68dodge] #2176341
10/16/16 08:55 PM
10/16/16 08:55 PM
Ohio
lockjaw-express Offline
Ohio
I wonder how the Wilson merge spacer would help a 4150 throttle body with direct port fuel injection?
Would be interesting to try, but expensive if no returns...
Mark
Re: Carburetor spacers [Re: 68dodge] #2176349
10/16/16 09:01 PM
10/16/16 09:01 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Spacers are usually a benefit. When you have too much, all that happens is that nothing new is noticed. Open, four hole, 1 or 2 inch changes can usually be felt seat of the pants.
[image][/image]
Re: Carburetor spacers [Re: 68dodge] #2176352
10/16/16 09:04 PM
10/16/16 09:04 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My 440 RB picked up .15 and 1.5mph going from a 1" 4 hole spacer to a 2" supersucker, runs were within an hour of each other.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Carburetor spacers [Re: 68dodge] #2176361
10/16/16 09:11 PM
10/16/16 09:11 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Never tested with or without on the dyno but my results are opposite of what you would expect. With both a 1" open and then a 1" taper 4 hole I lost 2/10ths and 4 MPH. Now we have determined this is due to the lack of space between the carb and the hood of my car. I need to go up, but hood choices that are functional and look good for a 3rd Gen Charger are far and few between.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Carburetor spacers [Re: Wookie316] #2176376
10/16/16 09:22 PM
10/16/16 09:22 PM
You already know the answer to this by it slowing down by adding plenum voluem, the carb. is to close to the hood shruggy Fix it and retests it and let us know your results then sawzall
Re: Carburetor spacers [Re: 68dodge] #2176391
10/16/16 09:35 PM
10/16/16 09:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Not even close to fit under a hood,Results next summer but I did use it with a teamG years ago.
Re: Carburetor spacers [Re: 68dodge] #2176415
10/16/16 09:56 PM
10/16/16 09:56 PM
Locomotion Offline
Locomotion  Offline
I haven't tested different ones, but did go with a 1" tapered spacer from Canton. To make sure you get the most out of any one you try, you should experiment with jetting, squirter size and squirt duration. In theory, increasing plenum volume may require more.
Re: Carburetor spacers [Re: 68dodge] #2176613
10/17/16 01:14 AM
10/17/16 01:14 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Dyno results showed best HP and Tq with a 2in spacer with tapered holes
on my 408 with Indy heads
Dan
Re: Carburetor spacers [Re: Wookie316] #2176865
10/17/16 01:54 PM
10/17/16 01:54 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
When i first put the 1050 dominator on my car with a 2" adaptor it lost 5mph at the top end to my 950 hp, took the hood off and it ran a pb.
Mick
best 60ft 1.36
Re: Carburetor spacers [Re: 68dodge] #2176923
10/17/16 02:43 PM
10/17/16 02:43 PM
an8sec70cuda Offline
Spacers are so combo specific, you just need to try them and see. If you gave us a rundown of your combo, we may be able to tell what it would most likely improve with.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Carburetor spacers [Re: lockjaw-express] #2176940
10/17/16 03:03 PM
10/17/16 03:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Mark
Save your money. Will likely make ZERO difference on a direct port car. Plenum spacers have to do with air speed and atomization on cars with carbs. You don't have that issue. Look at EFI cars of various configurations. Throttle body on top, front, rear, side, etc............It simply doesn't matter
Re: Carburetor spacers [Re: 68dodge] #2176955
10/17/16 03:17 PM
10/17/16 03:17 PM
Ohio
Ohio
Thank you Monte!
