Re: Carburetor spacers
[Re: 68dodge]
#2176081
10/16/16 03:22 PM
10/16/16 03:22 PM
Posts: 43,116 Bend,OR USA
Cab_Burge
I've used both open and four hole spacers in both hieghts, try it let us know how much faster your car goes with each one
[Re: 68dodge]
#2176089
10/16/16 03:35 PM
10/16/16 03:35 PM
Posts: 20,745 A collage of whims
topside
A collage of whims
I've done it on the dyno, and on that particular engine various combinations make some (8-10HP/TQ) difference. Tried 1" open, 1" 4-hole, 2" open, 2" 4-hole, swapping around between 1", 2", combining the two 1", etc on a 358" SB drag-race motor.
[Re: 68dodge]
#2176259
10/16/16 07:20 PM
10/16/16 07:20 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
both of my buddies picked up 15 hp on the dyno with those fancy 2" tapered spacers. One has the Wilson the other is HVH or something like that. One is BBM and one is SBC.
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: 68dodge]
#2176349
10/16/16 09:01 PM
10/16/16 09:01 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Spacers are usually a benefit. When you have too much, all that happens is that nothing new is noticed. Open, four hole, 1 or 2 inch changes can usually be felt seat of the pants.
[image][/image]
[Re: 68dodge]
#2176352
10/16/16 09:04 PM
10/16/16 09:04 PM
Posts: 3,210 robin hood country
deaks
robin hood country
My 440 RB picked up .15 and 1.5mph going from a 1" 4 hole spacer to a 2" supersucker, runs were within an hour of each other. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 68dodge]
#2176361
10/16/16 09:11 PM
10/16/16 09:11 PM
Posts: 326 Alberta
Wookie316
Alberta
Never tested with or without on the dyno but my results are opposite of what you would expect. With both a 1" open and then a 1" taper 4 hole I lost 2/10ths and 4 MPH. Now we have determined this is due to the lack of space between the carb and the hood of my car. I need to go up, but hood choices that are functional and look good for a 3rd Gen Charger are far and few between.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2176865
10/17/16 01:54 PM
10/17/16 01:54 PM
deaks
robin hood country
Never tested with or without on the dyno but my results are opposite of what you would expect. With both a 1" open and then a 1" taper 4 hole I lost 2/10ths and 4 MPH. Now we have determined this is due to the lack of space between the carb and the hood of my car. I need to go up, but hood choices that are functional and look good for a 3rd Gen Charger are far and few between. When i first put the 1050 dominator on my car with a 2" adaptor it lost 5mph at the top end to my 950 hp, took the hood off and it ran a pb. Mick
[Re: 68dodge]
#2176923
10/17/16 02:43 PM
10/17/16 02:43 PM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
Spacers are so combo specific, you just need to try them and see. If you gave us a rundown of your combo, we may be able to tell what it would most likely improve with.
[Re: lockjaw-express]
#2176940
10/17/16 03:03 PM
10/17/16 03:03 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I wonder how the Wilson merge spacer would help a 4150 throttle body with direct port fuel injection?
Would be interesting to try, but expensive if no returns...
Mark Save your money. Will likely make ZERO difference on a direct port car. Plenum spacers have to do with air speed and atomization on cars with carbs. You don't have that issue. Look at EFI cars of various configurations. Throttle body on top, front, rear, side, etc............It simply doesn't matter
