oval merge collector #2175118
10/15/16 10:29 AM
10/15/16 10:29 AM
pennsylvania
poboyengineering Offline OP
pennsylvania
we were unloading my friends car yesterday, and his merge collectors are catching at the end of his beavertail. One idea is to remove the collectors and put them in a vise, making them oval to gain clearance. The question is, how much will this hurt their performance?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: oval merge collector [Re: poboyengineering] #2175167
10/15/16 11:52 AM
10/15/16 11:52 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Carry a 6x6 block of wood and jack up the trailer 3-4 inches. Simple fix
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: oval merge collector [Re: poboyengineering] #2175262
10/15/16 02:05 PM
10/15/16 02:05 PM
pennsylvania
pennsylvania
we got a set of Rino ramps, and that just moved the problem from the lip (where the ramps clip on) to the break at the beavertail.
Re: oval merge collector [Re: poboyengineering] #2175265
10/15/16 02:12 PM
10/15/16 02:12 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I used to crank the front of my trailer up higher. then I bought a set of 7' ramps. problem solved. I don't think oval collectors would hurt, as they would still have the same area.
Re: oval merge collector [Re: poboyengineering] #2175275
10/15/16 02:30 PM
10/15/16 02:30 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
I just put a couple 2x10s on top of the ramps to raise up the car.
Re: oval merge collector [Re: Airwoofer] #2175293
10/15/16 03:09 PM
10/15/16 03:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've used two short pieces (2ft long)of 2x6 to lay on the trailer so the front tires go up when the exhaust is crossing the beavertail scope
I ended up nailing them to one of the trailers that had a wood floor, bolts work on metal floors work
Re: oval merge collector [Re: mopar dave] #2175315
10/15/16 04:27 PM
10/15/16 04:27 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Nope. Same perimiter but not same area. For any given perimeter a circle has a larger area than any other shape.
Re: oval merge collector [Re: GomangoCuda] #2175326
10/15/16 05:00 PM
10/15/16 05:00 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, I thought I read an add a while back about oval tubing having same area as round.
