oval merge collector
#2175118
10/15/16 10:29 AM
10/15/16 10:29 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
we were unloading my friends car yesterday, and his merge collectors are catching at the end of his beavertail. One idea is to remove the collectors and put them in a vise, making them oval to gain clearance. The question is, how much will this hurt their performance?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: oval merge collector
[Re: poboyengineering]
#2175167
10/15/16 11:52 AM
10/15/16 11:52 AM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Carry a 6x6 block of wood and jack up the trailer 3-4 inches. Simple fix
#2175262
10/15/16 02:05 PM
10/15/16 02:05 PM
poboyengineering
pennsylvania
we got a set of Rino ramps, and that just moved the problem from the lip (where the ramps clip on) to the break at the beavertail.
#2175265
10/15/16 02:12 PM
10/15/16 02:12 PM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I used to crank the front of my trailer up higher. then I bought a set of 7' ramps. problem solved. I don't think oval collectors would hurt, as they would still have the same area.
[Re: Airwoofer]
#2175293
10/15/16 03:09 PM
10/15/16 03:09 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
I've used two short pieces (2ft long)of 2x6 to lay on the trailer so the front tires go up when the exhaust is crossing the beavertail I ended up nailing them to one of the trailers that had a wood floor, bolts work on metal floors
[Re: mopar dave]
#2175315
10/15/16 04:27 PM
10/15/16 04:27 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
I don't think oval collectors would hurt, as they would still have the same area. Nope. Same perimiter but not same area. For any given perimeter a circle has a larger area than any other shape.
