Hi torque starter recommendation #2174511
10/14/16 01:23 PM
10/14/16 01:23 PM
Bloomington, IN
HoosierTA Offline OP
Bloomington, IN
Just finishing up on the RT restoration. It has been a while since I bought a high torque starter to replace the slow heavy factory one.
recommendations for brand, etc? Engine is a big block.
thanks,
'70 Challenger R/T 383
'16 Hemi Durango SSV (work vehicle)
'15 Ram Police SSV
Re: Hi torque starter recommendation [Re: HoosierTA] #2174535
10/14/16 02:06 PM
10/14/16 02:06 PM
None
71rm23 Offline
71rm23  Offline
None
Hoosier:
440 source has them, Mancini, Hughes Engines, etc. Wide range of choices and prices. Also, local parts store should have a Ram starter from '99-2004(?) 5.9 Magnum starter, which is basically the same.
http://www.manciniracing.com/search-resu...p;Submit=Search
http://store.440source.com/Starters/products/63/
http://www.hughesengines.com/Index/products.php?browse=search&search=starter&submit=Go
I got the 440 source one because it had the starter shield and mounting hardware, which I was missing. Had a mount stud break off in my block.
Cheers
Re: Hi torque starter recommendation [Re: 71rm23] #2174543
10/14/16 02:25 PM
10/14/16 02:25 PM
dogdays Offline
dogdays  Offline
Doesn't the Mopar mini starter work here? There are many members turning some pretty big mills with a stock mini starter.
I seem to remember Robb McC having high torque starters and he's a pretty good guy.
http://www.robbmcperformance.com/products/starter_home.html#comparison
R.
Re: Hi torque starter recommendation [Re: HoosierTA] #2174562
10/14/16 03:07 PM
10/14/16 03:07 PM
Bloomington, IN
Bloomington, IN
I was familiar with people using the starter for from the Dakotas, but not sure what kind of adapting might have needed done.
'15 Ram Police SSV
Re: Hi torque starter recommendation [Re: HoosierTA] #2174567
10/14/16 03:13 PM
10/14/16 03:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Any 90's ram, dakota or ram van with a magnum v6 or v8 engine. No adapting needed. You *may* have to take your angle grinder and shorten the 12v battery stud on the starter if you're running a big block. I think I had to shave mine down a 1/8 inch or so.
Re: Hi torque starter recommendation [Re: DaytonaTurbo] #2174643
10/14/16 04:34 PM
10/14/16 04:34 PM
Central TX
roe Offline
roe  Offline
Central TX
Yep the factory magnum starters are awesome. Spin motors like nothing...
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Hi torque starter recommendation [Re: HoosierTA] #2174651
10/14/16 04:47 PM
10/14/16 04:47 PM
Bloomington, IN
Bloomington, IN
just ordered the stuff from 440 source. Thanks,
'15 Ram Police SSV
Re: Hi torque starter recommendation [Re: HoosierTA] #2174675
10/14/16 05:11 PM
10/14/16 05:11 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
If your on a budget the factory magnum starter - you may have to mess with the terminals to clear the block, depending on block and style you get.
If your a big baller the Robb McC one is indeed pretty awesome - plus it lets you clock the solenoid wherever you like for optimal header clearance.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: Hi torque starter recommendation [Re: HoosierTA] #2174697
10/14/16 05:49 PM
10/14/16 05:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a Ram 360 for a 99 Durango.there are at least two of them the 360 is the big one.Mines an Advanced reman and been cranking nmy 12.5 440 since at least 2000.My kid used the 440 Source one in his 62 413.No problems with it either.I did have to cut the studs down a bit for clearance to block.Not a big deal just nut them cut a bit off and the undo the nuts.Rocky
Chrysler Firepower
Re: Hi torque starter recommendation [Re: therocks] #2174789
10/14/16 08:08 PM
10/14/16 08:08 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I've had good luck with the 440 Source starters
Abe Lincoln
Re: Hi torque starter recommendation [Re: dart4forte] #2174816
10/14/16 09:10 PM
10/14/16 09:10 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
I realize you have already ordered one but I have been very pleased with the RobbMc starter. The latest design is even better than the original. The customer support is topnotch. When I cooked it trying to start the car with a bad distributor (I should know better) he rebuilt it for a very fair price and to the latest design.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Hi torque starter recommendation [Re: HoosierTA] #2175162
10/15/16 11:45 AM
10/15/16 11:45 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Factory Magnum V8 starter cranks my 15-1 572 with a full 34 degrees of fixed timing. 4 years, approaching 400 passes.
Doug
