Hi torque starter recommendation
#2174511
10/14/16 01:23 PM
10/14/16 01:23 PM
Posts: 4,225 Bloomington, IN
HoosierTA
Bloomington, IN
Just finishing up on the RT restoration. It has been a while since I bought a high torque starter to replace the slow heavy factory one.
recommendations for brand, etc? Engine is a big block.
thanks,
'70 Challenger R/T 383 '16 Hemi Durango SSV (work vehicle) '15 Ram Police SSV
Re: Hi torque starter recommendation
[Re: 71rm23]
#2174543
10/14/16 02:25 PM
10/14/16 02:25 PM
dogdays
Doesn't the Mopar mini starter work here? There are many members turning some pretty big mills with a stock mini starter. I seem to remember Robb McC having high torque starters and he's a pretty good guy. http://www.robbmcperformance.com/products/starter_home.html#comparisonR.
[Re: HoosierTA]
#2174562
10/14/16 03:07 PM
10/14/16 03:07 PM
HoosierTA
Bloomington, IN
I was familiar with people using the starter for from the Dakotas, but not sure what kind of adapting might have needed done.
[Re: DaytonaTurbo]
#2174643
10/14/16 04:34 PM
10/14/16 04:34 PM
Posts: 3,344 Central TX
roe
Central TX
Yep the factory magnum starters are awesome. Spin motors like nothing...
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: HoosierTA]
#2174651
10/14/16 04:47 PM
10/14/16 04:47 PM
HoosierTA
Bloomington, IN
just ordered the stuff from 440 source. Thanks,
[Re: HoosierTA]
#2174675
10/14/16 05:11 PM
10/14/16 05:11 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
If your on a budget the factory magnum starter - you may have to mess with the terminals to clear the block, depending on block and style you get.
If your a big baller the Robb McC one is indeed pretty awesome - plus it lets you clock the solenoid wherever you like for optimal header clearance.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: HoosierTA]
#2174697
10/14/16 05:49 PM
10/14/16 05:49 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
I run a Ram 360 for a 99 Durango.there are at least two of them the 360 is the big one.Mines an Advanced reman and been cranking nmy 12.5 440 since at least 2000.My kid used the 440 Source one in his 62 413.No problems with it either.I did have to cut the studs down a bit for clearance to block.Not a big deal just nut them cut a bit off and the undo the nuts.Rocky
Chrysler Firepower
[Re: therocks]
#2174789
10/14/16 08:08 PM
10/14/16 08:08 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
I've had good luck with the 440 Source starters
Abe Lincoln
