71 Challenger Fender Emblem Location #2154422
09/14/16 03:13 PM
09/14/16 03:13 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Recently the "R/T" emblem was discussed, but I didn't see where it came up. Looking for the location of the script "Challenger" emblem on the fender for a 71 challenger that has the R/T stripe. I have a copy of the factory drawing that shows the R/T emblem placement. But off that drawing I'm not able to figure out the script emblem placement.
Re: 71 Challenger Fender Emblem Location [Re: Mopar.70] #2166339
10/02/16 10:28 AM
10/02/16 10:28 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
One more try...
Re: 71 Challenger Fender Emblem Location [Re: Mopar.70] #2166408
10/02/16 01:26 PM
10/02/16 01:26 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
since you haven't had any response ..... I will add this photo of mine. hope it helps !
Re: 71 Challenger Fender Emblem Location [Re: Mopar.70] #2166530
10/02/16 04:39 PM
10/02/16 04:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'll assume you have this factory print?, if so it won't help with the "lone" 71 Challenger script/emblem with stripe pkg
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2166531
10/02/16 04:40 PM
10/02/16 04:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's the factory stripe print if you need that?
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2166534
10/02/16 04:42 PM
10/02/16 04:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Unless a member can supply original location/measurements for you, the best might be to estimate from a factory picture
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2166540
10/02/16 04:48 PM
10/02/16 04:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2166561
10/02/16 05:19 PM
10/02/16 05:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you "draw" lines from the front marker light to the Challenger script/emblem they appear on different planes (one appears "above" the side marker, while the other appears "in-line" with the side marker) on these factory pics, like most things Mopar there are many variations, just like the R/T emblem placement on 70 challenger grilles, So IMHO whether you use factory prints, actual measurements from any source, a guess/estimation?, there will always be someone to "challenge" your final decision regardless of your source
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2167088
10/03/16 03:19 PM
10/03/16 03:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's funny that this drawing shows the 71 RT emblem location in relation to the Challenger emblem but shows the 70 badge locations
Re: 71 Challenger Fender Emblem Location [Re: Morty426] #2167548
10/04/16 07:30 AM
10/04/16 07:30 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I "played" sawzall with these two drawings a little scope
it looks like the '70 "Challenger" script is .16" forward compared to '71
it looks like the '70 "Challenger" script is 5.00" above the '71 placement
interesting no the '71 "R/T" placement makes NO mention of with or without stripes or body side mouldings
what is a practical reference to the "0" lines?
front to back work engine/transmission parting line?
bottom to top work centerline of crankshaft?
left to right whistling center of car
any comments/clarifications?
Re: 71 Challenger Fender Emblem Location [Re: 6bblgt] #2167730
10/04/16 02:39 PM
10/04/16 02:39 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Generally any reference to the "Zero/O" line in the Architectural/drafting/machine part print/etc world is in regard to a 'draftsman's SCALE ruler' (those triangular/3 sided white scale rulers) the "Zero/O" reference line (the "zero" starting line on the scale desired that your measurements will be based on) will vary depending on the print scale deployed, and will be located at different points on the various rule's scales depending on what scale was chosen
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2167765
10/04/16 03:29 PM
10/04/16 03:29 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
sorry, NO!
the "0" on these drawings has nothing to do with scale, it's the intersection of the X, Y, & Z-planes that represent the starting point for all dimensions - it is constant
Re: 71 Challenger Fender Emblem Location [Re: 6bblgt] #2167864
10/04/16 05:57 PM
10/04/16 05:57 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
sorry, NO!
Actually it has to do with both. It does references a point in space measured from 0,0 but also has a scale of 1 inch. A Challenger fender emblem is ~7 inches in length which is close to the sum of the dims.
But lets try to put this to sleep since we really don't know where 0,0 is on a car. So...
We (or I) know where an emblem goes on a F series (70). The bottom of the "G" is ~1" above the body line. Since 71s are 5" lower (thanks Dan) it then should be 4" below the body line. That places the "C" (passenger side) ~4" from the edge of the fender, but the drawing shows it's offset 0.16" from the reference.
So that means the passenger emblem would be 3.84" to the "C" from the fender edge and 4" to the bottom of the "g" from the body line.
wrench
Re: 71 Challenger Fender Emblem Location [Re: Mopar.70] #2168231
10/05/16 09:16 AM
10/05/16 09:16 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Stick them on where you think they look best. Unless someone turns up a picture of the car the day it turned up at the dealers, how can anyone tell you the emblems are in the wrong place?
Re: 71 Challenger Fender Emblem Location [Re: TiMopar] #2168390
10/05/16 02:37 PM
10/05/16 02:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, I'm sure no 2 cars are "surgically exact" in this regard, as it was an adhesive backed decal, there may have been a mask used on the assy. line to generalize location? or it may have been up to the individual working the line that day as to where it was placed
Re: 71 Challenger Fender Emblem Location [Re: DAYCLONA] #2168516
10/05/16 06:04 PM
10/05/16 06:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Totally agree! Plus if they had a template I wouldn't be surprised if they mixed up left and right. I have two Challengers with their original hoods. They should have three holes for the engine call out (one 440 SIXPACK and the other 426 HEMI) yet they both have 4 holes because they used the wrong template on the wrong side and had to add a hole.
Re: 71 Challenger Fender Emblem Location [Re: Mopar.70] #2172366
10/11/16 07:33 PM
10/11/16 07:33 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Thanks for the replies guys. I was away on vacation. Will review all the posts and go from there.
