Re: 71 Challenger Fender Emblem Location
[Re: Mopar.70]
#2166530
10/02/16 04:39 PM
10/02/16 04:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Recently the "R/T" emblem was discussed, but I didn't see where it came up. Looking for the location of the script "Challenger" emblem on the fender for a 71 challenger that has the R/T stripe. I have a copy of the factory drawing that shows the R/T emblem placement. But off that drawing I'm not able to figure out the script emblem placement. I'll assume you have this factory print?, if so it won't help with the "lone" 71 Challenger script/emblem with stripe pkg
[Re: DAYCLONA]
#2166540
10/02/16 04:48 PM
10/02/16 04:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#2167088
10/03/16 03:19 PM
10/03/16 03:19 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Recently the "R/T" emblem was discussed, but I didn't see where it came up. Looking for the location of the script "Challenger" emblem on the fender for a 71 challenger that has the R/T stripe. I have a copy of the factory drawing that shows the R/T emblem placement. But off that drawing I'm not able to figure out the script emblem placement. I'll assume you have this factory print?, if so it won't help with the "lone" 71 Challenger script/emblem with stripe pkg It's funny that this drawing shows the 71 RT emblem location in relation to the Challenger emblem but shows the 70 badge locations
[Re: Morty426]
#2167548
10/04/16 07:30 AM
10/04/16 07:30 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
I "played" with these two drawings a little it looks like the '70 "Challenger" script is .16" forward compared to '71 it looks like the '70 "Challenger" script is 5.00" above the '71 placement interesting the '71 "R/T" placement makes NO mention of with or without stripes or body side mouldings what is a practical reference to the "0" lines? front to back engine/transmission parting line? bottom to top centerline of crankshaft? left to right center of car any comments/clarifications?
[Re: 6bblgt]
#2167730
10/04/16 02:39 PM
10/04/16 02:39 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Generally any reference to the "Zero/O" line in the Architectural/drafting/machine part print/etc world is in regard to a 'draftsman's SCALE ruler' (those triangular/3 sided white scale rulers) the "Zero/O" reference line (the "zero" starting line on the scale desired that your measurements will be based on) will vary depending on the print scale deployed, and will be located at different points on the various rule's scales depending on what scale was chosen
[Re: DAYCLONA]
#2167765
10/04/16 03:29 PM
10/04/16 03:29 PM
6bblgt
Las Vegas, NV
Generally any reference to the "Zero/O" line in the Architectural/drafting/machine part print/etc world is in regard to a 'draftsman's SCALE ruler' (those triangular/3 sided white scale rulers) the "Zero/O" reference line (the "zero" starting line on the scale desired that your measurements will be based on) will vary depending on the print scale deployed, and will be located at different points on the various rule's scales depending on what scale was chosen sorry, NO! the "0" on these drawings has nothing to do with scale, it's the intersection of the X, Y, & Z-planes that represent the starting point for all dimensions - it is constant
[Re: 6bblgt]
#2167864
10/04/16 05:57 PM
10/04/16 05:57 PM
Morty426
Sacramento CA
Generally any reference to the "Zero/O" line in the Architectural/drafting/machine part print/etc world is in regard to a 'draftsman's SCALE ruler' (those triangular/3 sided white scale rulers) the "Zero/O" reference line (the "zero" starting line on the scale desired that your measurements will be based on) will vary depending on the print scale deployed, and will be located at different points on the various rule's scales depending on what scale was chosen sorry, NO! the "0" on these drawings has nothing to do with scale, it's the intersection of the X, Y, & Z-planes that represent the starting point for all dimensions - it is constant Actually it has to do with both. It does references a point in space measured from 0,0 but also has a scale of 1 inch. A Challenger fender emblem is ~7 inches in length which is close to the sum of the dims. But lets try to put this to sleep since we really don't know where 0,0 is on a car. So... We (or I) know where an emblem goes on a F series (70). The bottom of the "G" is ~1" above the body line. Since 71s are 5" lower (thanks Dan) it then should be 4" below the body line. That places the "C" (passenger side) ~4" from the edge of the fender, but the drawing shows it's offset 0.16" from the reference. So that means the passenger emblem would be 3.84" to the "C" from the fender edge and 4" to the bottom of the "g" from the body line.
[Re: TiMopar]
#2168390
10/05/16 02:37 PM
10/05/16 02:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Stick them on where you think they look best. Unless someone turns up a picture of the car the day it turned up at the dealers, how can anyone tell you the emblems are in the wrong place? Agreed, I'm sure no 2 cars are "surgically exact" in this regard, as it was an adhesive backed decal, there may have been a mask used on the assy. line to generalize location? or it may have been up to the individual working the line that day as to where it was placed
[Re: DAYCLONA]
#2168516
10/05/16 06:04 PM
10/05/16 06:04 PM
Morty426
Sacramento CA
Stick them on where you think they look best. Unless someone turns up a picture of the car the day it turned up at the dealers, how can anyone tell you the emblems are in the wrong place? Agreed, I'm sure no 2 cars are "surgically exact" in this regard, as it was an adhesive backed decal, there may have been a mask used on the assy. line to generalize location? or it may have been up to the individual working the line that day as to where it was placed Totally agree! Plus if they had a template I wouldn't be surprised if they mixed up left and right. I have two Challengers with their original hoods. They should have three holes for the engine call out (one 440 SIXPACK and the other 426 HEMI) yet they both have 4 holes because they used the wrong template on the wrong side and had to add a hole.
