4 speed crank bushing #2160928
09/24/16 04:05 PM
09/24/16 04:05 PM
MN
58pwrwgn Offline OP
58pwrwgn  Offline OP
MN
I have a 440. The crank is drilled but it doesn't have a bushing installed. It appears I need a 7/8 o.d. x 3/4 i.d.
Is this something I can find at the hardware store and just install.
Would I be better off to wait and get the roller bearing that fits in the converter hub opening
Re: 4 speed crank bushing [Re: 58pwrwgn] #2160949
09/24/16 04:41 PM
09/24/16 04:41 PM
AndyF Offline
AndyF  Offline
Why not just buy the correct bushing? You aren't going to find it at a hardware store but you can get it from a Mopar parts dealer.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2160960
09/24/16 05:06 PM
09/24/16 05:06 PM
MN
58pwrwgn Offline OP
58pwrwgn  Offline OP
MN
It was something I was going to put in today and just noticed it. Is the hole in the crank finished/reamed to size for the bushing, its a 70's steel crank motor.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2160964
09/24/16 05:20 PM
09/24/16 05:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You might find the right bushing at the parts store, NAPA comes to mind.
Don't be the exception.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2160965
09/24/16 05:21 PM
09/24/16 05:21 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
there is a good chance your local auto parts store might have the correct one..... they did for my sisters mustang..
Some advice... Slide it over your transmission output shaft before installing to make sure it is correct..
Spent a week trying to install my friends new 289/4-speed in his 57 ford ( back in the day) before we had to pull it out to find out the ID of the bushing was too small.... LOL, but not funny back then.....
Re: 4 speed crank bushing [Re: 58pwrwgn] #2161030
09/24/16 08:25 PM
09/24/16 08:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most cranks are pilot drilled to .915" and then finally reamed to .9375" if a bushing is to be installed. Undersized bushings are available.
http://www.ebay.com/itm/like/261638021109?lpid=82&chn=ps&ul_noapp=true
Or use the bearing/bushing that installs in the converter register.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2161041
09/24/16 08:48 PM
09/24/16 08:48 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I rebuilt a 383 once about 30 years ago that had the proper diameter recess in the crank, the pilot bushing fit, but the A833 would not - the hole wasn't deep enough! The crank had come out of an automatic car, apparently.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2161162
09/25/16 01:19 AM
09/25/16 01:19 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
The hole was deep enough but not finish reamed in the steel crank of the '72 440 in my Diplomat. I just went and got one of the roller bearings like shown above at Advance Auto. Works just fine.
I have several other '72 440s and the regular bronze bushings have fit in em.
Re: 4 speed crank bushing [Re: 58pwrwgn] #2161227
09/25/16 09:05 AM
09/25/16 09:05 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Most likely that crank would need pulled and finished to the proper size.
The late model style that kunkel shows are the way to go. And they should be available at a parts store.
Note, if the crank isn't drilled deep enough, you can trim the input shaft.
Angry white pureblood male
Re: 4 speed crank bushing [Re: 58pwrwgn] #2161281
09/25/16 11:37 AM
09/25/16 11:37 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Or just drill the hole a little deeper (not finish size of course, just big enough for the input shaft tip to clear). That's what I did rather than take the whole bottom end apart again.
Re: 4 speed crank bushing [Re: DrCharles] #2162099
09/26/16 03:53 PM
09/26/16 03:53 PM
dogdays Offline
dogdays  Offline
That's using your head.
I drilled and tapped that giant steel washer so I could easily pull it out. There's enough room for a 1/4-20 thread.
R.
