Re: 4 speed crank bushing
[Re: 58pwrwgn]
#2160964
09/24/16 05:20 PM
09/24/16 05:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You might find the right bushing at the parts store, NAPA comes to mind.
[Re: 58pwrwgn]
#2160965
09/24/16 05:21 PM
09/24/16 05:21 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
It was something I was going to put in today and just noticed it. Is the hole in the crank finished/reamed to size for the bushing, its a 70's steel crank motor. there is a good chance your local auto parts store might have the correct one..... they did for my sisters mustang.. Some advice... Slide it over your transmission output shaft before installing to make sure it is correct.. Spent a week trying to install my friends new 289/4-speed in his 57 ford ( back in the day) before we had to pull it out to find out the ID of the bushing was too small.... LOL, but not funny back then.....
[Re: 58pwrwgn]
#2161227
09/25/16 09:05 AM
09/25/16 09:05 AM
Posts: 5,836 ohio
ruderunner
ohio
Most likely that crank would need pulled and finished to the proper size.
The late model style that kunkel shows are the way to go. And they should be available at a parts store.
Note, if the crank isn't drilled deep enough, you can trim the input shaft.
Angry white pureblood male
