23psi of boost + Cast Crank =.....(answer inside!) #2155741
09/16/16 02:28 PM
09/16/16 02:28 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
23psi of boost + Cast Crank = New best!!!!
Went to Milan last night... and the track was GARBAGE. Had to turn the launch WAY down even with the new Pro 275 tires on it. Only went 1.42 60ft, but man is it making some steam now...
60ft - 1.425
330ft - 3.978
660ft - 6.118
660mph - 114.66
1000ft - 7.973
1/4 - 9.552
1/4 MPH - 141.75
My Dad got some Video... I'll try to post it when I get it from him.
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155745
09/16/16 02:36 PM
09/16/16 02:36 PM
Detroit, Michigan
sbsatellite Offline
sbsatellite  Offline
Detroit, Michigan
The car is awesome to watch in person! Glad you could make it out.
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155784
09/16/16 03:34 PM
09/16/16 03:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That's gettin it done man........... beer
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155828
09/16/16 05:02 PM
09/16/16 05:02 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Congrats on new best. I seen better days at lapeer than milan. Seems milan doesn't prep much on TNT days.
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155837
09/16/16 05:25 PM
09/16/16 05:25 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You and your dad certainly can make mopars fly in different ways. up bow
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: B G Racing] #2155862
09/16/16 06:06 PM
09/16/16 06:06 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Maybe I should have held on to the cast 440 crank I gave away???
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155864
09/16/16 06:09 PM
09/16/16 06:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nice pass
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155865
09/16/16 06:10 PM
09/16/16 06:10 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's very impressive! From the thread title, though, I was expecting something that looks more like this: wink
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155868
09/16/16 06:18 PM
09/16/16 06:18 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Who say's cast cranks aren't strong... wink
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155887
09/16/16 06:47 PM
09/16/16 06:47 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Great work. Always like to see these kind of updates!
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155893
09/16/16 06:57 PM
09/16/16 06:57 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
Absolutely unreal. Congrats!
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155902
09/16/16 07:15 PM
09/16/16 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Congrats Scott up
wave
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155922
09/16/16 07:42 PM
09/16/16 07:42 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Congrats. I'm hoping to make it up there for the next No et deal at milan
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155938
09/16/16 08:21 PM
09/16/16 08:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I know of a n/a smallblock in the low 9`s w/a cast crank............
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155939
09/16/16 08:21 PM
09/16/16 08:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sounds encouraging for the cast crank GEN III too.
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155951
09/16/16 09:18 PM
09/16/16 09:18 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155977
09/16/16 10:54 PM
09/16/16 10:54 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Good job!
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155987
09/16/16 11:08 PM
09/16/16 11:08 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
WELL DONE MATE !!!! would love to have that car downunder. I have been 9.69 with a cast crank on the bottle in my 63
1963 Plymouth Max Wedge
1971 Barracuda
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2155992
09/16/16 11:31 PM
09/16/16 11:31 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
Here is a crazy thought - have you thought about spraying a small shot on it to get the 60ft down some? I know a lot of that is dependent on track prep or the lack thereof. A local LS tuner loves to spray the sbe Ls engines he tunes and with great results. He typically will leave on a 75 shot and spray it the whole pass. You may not want to push the poor cast crank that far though..
Re: 23psi of boost + Cast Crank =.....(answer inside!) [Re: dizuster] #2156052
09/17/16 02:18 AM
09/17/16 02:18 AM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
Nice!! I think that really shows what the stock block/crank can do when RPM's are kept low and big power is made via forced induction with a good tune! If your 3750lb car can run mod 9's on those parts it gives me hope that someday my 3550lb
car could possibly run high 9's when I get everything worked out (although the prochargers aren't quite as efficient as the turbo).
What's your take on the strength of the 90's block you have vs the earlier LA blocks?
