Re: 23psi of boost + Cast Crank =.....(answer inside!)
[Re: B G Racing]
#2155862
09/16/16 06:06 PM
09/16/16 06:06 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Maybe I should have held on to the cast 440 crank I gave away???
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: dizuster]
#2155887
09/16/16 06:47 PM
09/16/16 06:47 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Great work. Always like to see these kind of updates!
[Re: dizuster]
#2155938
09/16/16 08:21 PM
09/16/16 08:21 PM
Thumperdart
State of confusion
Who say's cast cranks aren't strong... I know of a n/a smallblock in the low 9`s w/a cast crank............
[Re: dizuster]
#2155987
09/16/16 11:08 PM
09/16/16 11:08 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
WELL DONE MATE !!!! would love to have that car downunder. I have been 9.69 with a cast crank on the bottle in my 63
1963 Plymouth Max Wedge 1971 Barracuda
[Re: dizuster]
#2156052
09/17/16 02:18 AM
09/17/16 02:18 AM
Posts: 370 Suffolk County, New York
1mean340
Nice!! I think that really shows what the stock block/crank can do when RPM's are kept low and big power is made via forced induction with a good tune! If your 3750lb car can run mod 9's on those parts it gives me hope that someday my 3550lb car could possibly run high 9's when I get everything worked out (although the prochargers aren't quite as efficient as the turbo).
What's your take on the strength of the 90's block you have vs the earlier LA blocks?
