Rocker Options for BB Trick Flow Heads #2146229
09/02/16 04:17 PM
09/02/16 04:17 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
I tried searching, can't remember, but someone recommended either Hughes or Mancini rockers. Any advice?
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146319
09/02/16 06:50 PM
09/02/16 06:50 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Search the trick flow Head thread I believe they cover rocker arms in the subject
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146351
09/02/16 07:33 PM
09/02/16 07:33 PM
Phoenix, AZ
68Charger440HP Offline
Phoenix, AZ
I used Crane Gold's on mine and they worked just fine. Here's a pic.
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146380
09/02/16 08:20 PM
09/02/16 08:20 PM
Spring Hill Fl
Spring Hill Fl
I started going through the 72 pages, was hoping someone would remember. I think it is Mancini that is selling the HS copies?
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146449
09/02/16 10:48 PM
09/02/16 10:48 PM
AndyF Offline
AndyF  Offline
All depends on how much money you want to spend and how much power you think you'll make. Also depends on the type of camshaft.
I just spent two days on the dyno testing RAS, MRE, Harland and T&D rocker arms on my 470 engine which has Trick Flow heads.
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146513
09/03/16 12:13 AM
09/03/16 12:13 AM
Spring Hill Fl
Spring Hill Fl
Do the MRE rockers have a decent scrub pattern?
Are there any other rockers in that price point that would be a good application for a street/strip engine with a 620ish lift FT cam in a 1.6 ratio?
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146557
09/03/16 01:11 AM
09/03/16 01:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using these Hughes 1.6 ratio roller tip rockers in my 440/493 since 2011. They are Manton pushrods and they have been holding up great on my street/strip car. Ron
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146603
09/03/16 02:44 AM
09/03/16 02:44 AM
AndyF Offline
AndyF  Offline
The MRE rockers will work just fine with a .620 lift flat tappet. I know where you can buy a slightly used set of those rockers.
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146605
09/03/16 02:50 AM
09/03/16 02:50 AM
Spring Hill Fl
Spring Hill Fl
I'm interested.
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146675
09/03/16 10:02 AM
09/03/16 10:02 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Not to thread-jack, but... I have had a set of the old comp gold rockers on my current 493 with a small solid flat tappet. I am looking to upgrade the cam when I swap on the Trick Flows, and would like to go roller, but I am not sure about the rockers being able to deal with the increased spring pressures. Any real world feedback on how much pressure the Cranes can take, or if they'd last with a street roller.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Rocker Options for BB Trick Flow Heads [Re: 65Fury440] #2146748
09/03/16 01:03 PM
09/03/16 01:03 PM
AndyF Offline
AndyF  Offline
I'm interested.
Shoot me a PM
Re: Rocker Options for BB Trick Flow Heads [Re: OUTLAWD] #2146751
09/03/16 01:05 PM
09/03/16 01:05 PM
AndyF Offline
AndyF  Offline
The Crane rockers will work with a street roller for a while. Don't know how long "a while" is, could be several years depending on how hard you beat on it and how much spring force you have. They'll fit and work on the TF heads with decent geometry. I checked them on my heads up past 0.700 lift and they were fine.
