Re: Rocker Options for BB Trick Flow Heads
[Re: 65Fury440]
#2146319
09/02/16 06:50 PM
09/02/16 06:50 PM
Posts: 1,030 ohio
67mprfan
ohio
Search the trick flow Head thread I believe they cover rocker arms in the subject
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 65Fury440]
#2146449
09/02/16 10:48 PM
09/02/16 10:48 PM
Posts: 31,050 Oregon
AndyF
I tried searching, can't remember, but someone recommended either Hughes or Mancini rockers. Any advice? All depends on how much money you want to spend and how much power you think you'll make. Also depends on the type of camshaft. I just spent two days on the dyno testing RAS, MRE, Harland and T&D rocker arms on my 470 engine which has Trick Flow heads.
[Re: 65Fury440]
#2146513
09/03/16 12:13 AM
09/03/16 12:13 AM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Do the MRE rockers have a decent scrub pattern? Are there any other rockers in that price point that would be a good application for a street/strip engine with a 620ish lift FT cam in a 1.6 ratio?
[Re: 65Fury440]
#2146603
09/03/16 02:44 AM
09/03/16 02:44 AM
AndyF
Do the MRE rockers have a decent scrub pattern? Are there any other rockers in that price point that would be a good application for a street/strip engine with a 620ish lift FT cam in a 1.6 ratio? The MRE rockers will work just fine with a .620 lift flat tappet. I know where you can buy a slightly used set of those rockers.
[Re: 65Fury440]
#2146675
09/03/16 10:02 AM
09/03/16 10:02 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Not to thread-jack, but... I have had a set of the old comp gold rockers on my current 493 with a small solid flat tappet. I am looking to upgrade the cam when I swap on the Trick Flows, and would like to go roller, but I am not sure about the rockers being able to deal with the increased spring pressures. Any real world feedback on how much pressure the Cranes can take, or if they'd last with a street roller.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: 65Fury440]
#2146748
09/03/16 01:03 PM
09/03/16 01:03 PM
AndyF
I'm interested. Shoot me a PM
[Re: OUTLAWD]
#2146751
09/03/16 01:05 PM
09/03/16 01:05 PM
AndyF
Not to thread-jack, but... I have had a set of the old comp gold rockers on my current 493 with a small solid flat tappet. I am looking to upgrade the cam when I swap on the Trick Flows, and would like to go roller, but I am not sure about the rockers being able to deal with the increased spring pressures. Any real world feedback on how much pressure the Cranes can take, or if they'd last with a street roller. The Crane rockers will work with a street roller for a while. Don't know how long "a while" is, could be several years depending on how hard you beat on it and how much spring force you have. They'll fit and work on the TF heads with decent geometry. I checked them on my heads up past 0.700 lift and they were fine.
