340 engine build date VS production date #2144784
08/31/16 07:05 PM
08/31/16 07:05 PM
Massachusetts
RAII4-speed Offline OP
Massachusetts
I am looking at a car that is a 1970 340 with a build date of 11/18/69 and a production date of 3/03/70 car was built in Hamtrack.
Does this seem correct?
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144803
08/31/16 07:24 PM
08/31/16 07:24 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Seems correct to me. Engines were in stock months before the were uses.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144806
08/31/16 07:25 PM
08/31/16 07:25 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Was engine assy date 11/18/69?
If so My both Cudas have a SPD of 4/18/70 , but the 340 engine assy dates are late January 1970 for both cars. Was not always 1st in 1st out.
Carbs where dated January also
Hope this helps
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144815
08/31/16 07:31 PM
08/31/16 07:31 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
11-18-69 sounds like a casting date?
The actual final assembly date is part of the engine serial number (not to be confused with the VIN) on the front of the block below the drivers side head surface.
The date there is in the 10,000 day calendar format.
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144816
08/31/16 07:32 PM
08/31/16 07:32 PM
Massachusetts
Massachusetts
Yes date on engine is 11/18/69 CASTING ON ENGINE.....
SPD is 3/03/70
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144818
08/31/16 07:38 PM
08/31/16 07:38 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Check the serial number on the front & report back.
My 417 SPD T/A had an engine assembly date of April 22, so I know the car was built later than the 'hoped for' SPD.
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144823
08/31/16 07:42 PM
08/31/16 07:42 PM
Massachusetts
Massachusetts
this is the car in question ....
http://www.ebay.com/itm/162178295084
Re: 340 engine build date VS production date [Re: RAII4-speed] #2144834
08/31/16 07:57 PM
08/31/16 07:57 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Look on front of Engine, here is where the info is.
Check out the maltese stamp and K5 Stamp
Re: 340 engine build date VS production date [Re: RAII4-speed] #2145009
08/31/16 11:04 PM
08/31/16 11:04 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is a purty car... drool
JB Rhinehart, Realist
A-Body's RULE!
Re: 340 engine build date VS production date [Re: VCODE] #2145122
09/01/16 01:19 AM
09/01/16 01:19 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Example engine was assembled Tuesday, January 20, 1970. This is the stamping we need.
*If you are still considering the purchase of this car (per our detailed phone conversation) you really should hire someone to do a 3rd party pre purchase inspection. .02
Re: 340 engine build date VS production date [Re: RAII4-speed] #2145280
09/01/16 11:59 AM
09/01/16 11:59 AM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
You have a PM about that car
Tried to send you a pm about the car, don't know if it went through... Pm me .
Re: 340 engine build date VS production date [Re: RAII4-speed] #2145400
09/01/16 02:43 PM
09/01/16 02:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
30000 miles? Then why did it need a complete restoration?
Re: 340 engine build date VS production date [Re: RAII4-speed] #2145411
09/01/16 02:52 PM
09/01/16 02:52 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Really??? 42.5k 🙄
Re: 340 engine build date VS production date [Re: ScottSmith_Harms] #2147226
09/04/16 11:48 AM
09/04/16 11:48 AM
Massachusetts
Massachusetts
Scott thanks for the advise on the 1970 Duster .... The owner is impossible to deal with therefor I have dismissed buying the car .... If you know of any others for sale, Please let me know
THANKS
John
