Re: New Edelbrock carb mixture screw quandary!
[Re: Hooligan]
#2141910
08/27/16 03:01 PM
08/27/16 03:01 PM
Posts: 4,848 Memphis
HemiRick
Memphis
That side of the idle circuit is probably clogged up....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2141915
08/27/16 03:08 PM
08/27/16 03:08 PM
RapidRobert
get a can of brake kleen or something similar with the thin red straw & give that port a healthy blast & see if that cleans things up
[Re: HemiRick]
#2141916
08/27/16 03:08 PM
08/27/16 03:08 PM
Posts: 570 USA
Hooligan
USA
That side of the idle circuit is probably clogged up.... Do you think I should blow some compressed air through the mixture screw hole?
[Re: RapidRobert]
#2141917
08/27/16 03:11 PM
08/27/16 03:11 PM
Posts: 570 USA
Hooligan
USA
get a can of brake kleen or something similar with the thin red straw & give that port a healthy blast & see if that cleans things up Thanks. I'll give that one a go as soon as I can go buy a can. The cabinets are bare.
[Re: Hooligan]
#2141922
08/27/16 03:17 PM
08/27/16 03:17 PM
RapidRobert
holler how it turns out & if no go we will continue on for a solution
[Re: RapidRobert]
#2141927
08/27/16 03:21 PM
08/27/16 03:21 PM
Posts: 570 USA
Hooligan
USA
holler how it turns out & if no go we will continue on for a solution OK, I will type out... "HELLLLLLLLLLP"!!!! if I need ya!
[Re: Hooligan]
#2141935
08/27/16 03:35 PM
08/27/16 03:35 PM
RapidRobert
Alright sounds like a plan & FYI go easy on the CAPS as there is a young man in Grand Prairie Texas who keeps us in line! Me I like em as my eyesight is fading but I gotta go with the flow
[Re: RapidRobert]
#2141947
08/27/16 03:47 PM
08/27/16 03:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Alright sounds like a plan & FYI go easy on the CAPS as there is a young man in Grand Prairie Texas who keeps us in line! Me I like em as my eyesight is fading but I gotta go with the flow CTRL + or CTRL - will zoom in and out for you.
[Re: RapidRobert]
#2141951
08/27/16 03:50 PM
08/27/16 03:50 PM
Posts: 570 USA
Hooligan
USA
Alright sounds like a plan & FYI go easy on the CAPS as there is a young man in Grand Prairie Texas who keeps us in line! Me I like em as my eyesight is fading but I gotta go with the flow No problem. I will lay off the caps, but instead I will press very hard on the keys. I guess I can omit the exclamation points too, so I keep under the Texas radar system.
[Re: Supercuda]
#2141966
08/27/16 04:09 PM
08/27/16 04:09 PM
RapidRobert
CTRL + or CTRL - will zoom in and out for you. Noted! EDIT By God that works perfect
[Re: Hooligan]
#2141997
08/27/16 04:50 PM
08/27/16 04:50 PM
Posts: 570 USA
Hooligan
USA
i'm so glad that my problem turned out to be a way to fix rapid robert's visual problem. i hate to think how long he was dealing wit it. ya see... i didn't use any caps! (oops. i used an exclamation point.) DANG IT!!!!!!
[Re: Hooligan]
#2142146
08/27/16 09:56 PM
08/27/16 09:56 PM
RapidRobert
How is the carburetor doing?
[Re: RapidRobert]
#2142149
08/27/16 10:10 PM
08/27/16 10:10 PM
Posts: 570 USA
Hooligan
USA
How is the carburetor doing? Crap! I fell asleep. No progress will happen until I buy some brake kleen tomorrow. Unless my neighbor has some in his garage, in which case, I have to wait for him to fall asleep so I can steal it. Hah!
[Re: RapidRobert]
#2142167
08/27/16 10:32 PM
08/27/16 10:32 PM
Posts: 570 USA
Hooligan
USA
How is the carburetor doing? Robert, Should I steal... er-uh, buy carburetor cleaner instead of brake kleen???
[Re: Hooligan]
#2142175
08/27/16 10:48 PM
08/27/16 10:48 PM
RapidRobert
any type of spray cleaner with the thin red straw will work to get up into that port. BK or starting fluid, anything along those lines
[Re: RapidRobert]
#2142179
08/27/16 11:01 PM
08/27/16 11:01 PM
Posts: 570 USA
Hooligan
USA
any type of spray cleaner with the thin red straw will work to get up into that port. BK or starting fluid, anything along those lines OK, cool. By this time tomorrow, my idle circuit will be fresh and clean at the very least. If that doesn't solve the problem, I'll call Edelbrock on Monday. I'm sure they are just sitting around doing nothing.
[Re: Hooligan]
#2142209
08/28/16 12:23 AM
08/28/16 12:23 AM
HemiRick
Memphis
calling them is not gonna take the carb apart and clean it.....
[Re: HemiRick]
#2142227
08/28/16 12:53 AM
08/28/16 12:53 AM
Posts: 570 USA
Hooligan
USA
calling them is not gonna take the carb apart and clean it..... Thanks for that observation. Actually, the phone call comes after the cleaning. It shouldn't be filthy inside since everything is brand new with under 100 miles on a newly rebuilt engine that is running great so far. New carb, new gas tank, new fuel lines, new fuel pump, and a new fuel filter. Not to say that some debris didn't get in the system during assembly, but we're not talking about a car that sat around without running for several years. It doesn't hurt to ask for their opinion, because they may have seen this problem before.
[Re: HemiRick]
#2142339
08/28/16 10:40 AM
08/28/16 10:40 AM
Posts: 570 USA
Hooligan
USA
calling them is not gonna take the carb apart and clean it..... What I really wanted to say to Hemi Rick is... "I can't believe you logged in to Moparts to say that unnecessary comment to me." "Please forgave me, but I thought Moparts was for promoting friendship and unity among Mopar enthusiasts, sharing knowledge, and having some fun!" "Some of us are trying to help each other get more Mopars back on the road." "I'm sorry if maybe your dog took a dump inside one of your shoes and caused you to have a negative attitude, but I don't think that your kind of commentary in this case, which you are trying to make me look stupid, has any place in Moparts." "Several members use this type of behavior, and cause fights." "It's very saddening to read things like that." "If you can't say something friendly and helpful to others, then please don't say anything at all." "Thank you to everyone else for your help and friendship!" ...and to anyone who has pets, remember to check your shoes before logging on!"
