Page 1 of 3 1 2 3
New Edelbrock carb mixture screw quandary! #2141909
08/27/16 02:59 PM
08/27/16 02:59 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Well, I have brand new Edelbrock 4 barrel carb. #1813S 4077. It is a copy of the Carter AVS. It's the weekend, so I can't call Edelbrock.
Anyway, the driver side mixture screw offers zero change to the engine idle when I adjust it. I even took it all the way out, and nothing happened. The passenger side mixture makes changes when I adjust it, and the engine idles and runs terrific. The throttle blades are definitely in the correct relation to the transfer slots. I poked a needle in the hole with the mixture screw out and it didn't feel plugged. The metering rod looks fine too.
Even though it runs great, I'm curious as to why I can't get any adjustment out of it.
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2141910
08/27/16 03:01 PM
08/27/16 03:01 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That side of the idle circuit is probably clogged up....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: New Edelbrock carb mixture screw quandary! [Re: HemiRick] #2141915
08/27/16 03:08 PM
08/27/16 03:08 PM
get a can of brake kleen or something similar with the thin red straw & give that port a healthy blast & see if that cleans things up
Re: New Edelbrock carb mixture screw quandary! [Re: HemiRick] #2141916
08/27/16 03:08 PM
08/27/16 03:08 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Do you think I should blow some compressed air through the mixture screw hole?
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2141917
08/27/16 03:11 PM
08/27/16 03:11 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Thanks. I'll give that one a go as soon as I can go buy a can. The cabinets are bare.
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2141922
08/27/16 03:17 PM
08/27/16 03:17 PM
holler how it turns out & if no go we will continue on for a solution
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2141927
08/27/16 03:21 PM
08/27/16 03:21 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
OK, I will type out... "HELLLLLLLLLLP"!!!! if I need ya!
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2141935
08/27/16 03:35 PM
08/27/16 03:35 PM
Alright sounds like a plan & FYI go easy on the CAPS as there is a young man in Grand Prairie Texas who keeps us in line! Me I like em as my eyesight is fading but I gotta go with the flow
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2141947
08/27/16 03:47 PM
08/27/16 03:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CTRL + or CTRL - will zoom in and out for you.
Don't be the exception.
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2141951
08/27/16 03:50 PM
08/27/16 03:50 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
No problem. I will lay off the caps, but instead I will press very hard on the keys. I guess I can omit the exclamation points too, so I keep under the Texas radar system.
Re: New Edelbrock carb mixture screw quandary! [Re: Supercuda] #2141966
08/27/16 04:09 PM
08/27/16 04:09 PM
Noted! EDIT By God that works perfect
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2141997
08/27/16 04:50 PM
08/27/16 04:50 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
i'm so glad that my problem turned out to be a way to fix rapid robert's visual problem. i hate to think how long he was dealing wit it. ya see... i didn't use any caps! (oops. i used an exclamation point.) DANG IT!!!!!!
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2142146
08/27/16 09:56 PM
08/27/16 09:56 PM
How is the carburetor doing?
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2142149
08/27/16 10:10 PM
08/27/16 10:10 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Crap! I fell asleep. No progress will happen until I buy some brake kleen tomorrow. Unless my neighbor has some in his garage, in which case, I have to wait for him to fall asleep so I can steal it. Hah!
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2142167
08/27/16 10:32 PM
08/27/16 10:32 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Robert, Should I steal... er-uh, buy carburetor cleaner instead of brake kleen???
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2142175
08/27/16 10:48 PM
08/27/16 10:48 PM
any type of spray cleaner with the thin red straw will work to get up into that port. BK or starting fluid, anything along those lines
Re: New Edelbrock carb mixture screw quandary! [Re: RapidRobert] #2142179
08/27/16 11:01 PM
08/27/16 11:01 PM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
OK, cool. By this time tomorrow, my idle circuit will be fresh and clean at the very least.
If that doesn't solve the problem, I'll call Edelbrock on Monday. I'm sure they are just sitting around doing nothing.
Re: New Edelbrock carb mixture screw quandary! [Re: Hooligan] #2142209
08/28/16 12:23 AM
08/28/16 12:23 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
calling them is not gonna take the carb apart and clean it.....
Take care,
Rick
Re: New Edelbrock carb mixture screw quandary! [Re: HemiRick] #2142227
08/28/16 12:53 AM
08/28/16 12:53 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
Thanks for that observation. Actually, the phone call comes after the cleaning. It shouldn't be filthy inside since everything is brand new with under 100 miles on a newly rebuilt engine that is running great so far. New carb, new gas tank, new fuel lines, new fuel pump, and a new fuel filter. Not to say that some debris didn't get in the system during assembly, but we're not talking about a car that sat around without running for several years. It doesn't hurt to ask for their opinion, because they may have seen this problem before.
Re: New Edelbrock carb mixture screw quandary! [Re: HemiRick] #2142339
08/28/16 10:40 AM
08/28/16 10:40 AM
USA
Hooligan Offline OP
Hooligan  Offline OP
USA
What I really wanted to say to Hemi Rick is... "I can't believe you logged in to Moparts to say that unnecessary comment to me." "Please forgave me, but I thought Moparts was for promoting friendship and unity among Mopar enthusiasts, sharing knowledge, and having some fun!" "Some of us are trying to help each other get more Mopars back on the road." "I'm sorry if maybe your dog took a dump inside one of your shoes and caused you to have a negative attitude, but I don't think that your kind of commentary in this case, which you are trying to make me look stupid, has any place in Moparts." "Several members use this type of behavior, and cause fights." "It's very saddening to read things like that." "If you can't say something friendly and helpful to others, then please don't say anything at all."
"Thank you to everyone else for your help and friendship!" ...and to anyone who has pets, remember to check your shoes before logging on!"
Page 1 of 3 1 2 3
