70 E-Body Quarter Glass Hardtop vs. Convertible #2135980
08/18/16 04:59 PM
08/18/16 04:59 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
Question about quarter glass:
Is the lower metal glass mounting structure and weather-strip/chrome-strip the same for both 70 E-Body hardtop and convertible models?
In other words, if I had a set of convertible quarter window assemblies, could I replace the glass with a hardtop glass, install them in my Cuda hardtop, and they would work?
The reference picture below is an NOS hardtop quarter window assembly that I found in another thread.
Thanks!
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2136660
08/19/16 03:08 PM
08/19/16 03:08 PM
Indianapolis, IN
Indianapolis, IN
Bump...
Anyone have any experience with this?
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2136850
08/19/16 09:30 PM
08/19/16 09:30 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I'm hoping a few pics will help you. These are from a challenger but I believe a Cuda may be the same. In the first pic, the clean window mount on the left, is from a 70 Challenger convertible. When you look at the web going between the 3 holes, on the convertible it's a "T" shaped more than the hardtop one, The top of the "T" is angled on the left. They also have different part numbers.
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2136854
08/19/16 09:34 PM
08/19/16 09:34 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
In this pic, I stacked the windows on top of one another and lined up two of the holes as seen by the light underneath. The hole with the slide still mounted appeared to be slightly misaligned from the convertible glass on the bottom. The stainless trim on the hardtop was about one half inch longer( could be cut).
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2136857
08/19/16 09:39 PM
08/19/16 09:39 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's where I noticed the big difference was the tilt of the glass when the seal end and the two holes are lined up. The back bottom edge was in a different position by almost an inch. Usually the Challenger and Cuda convertible hardware like this is interchangeable. I believe the way to tell at a glance which is convertible and which is hardtop is by the webbing line going between the holes. I hope this was somewhat informative.
Terry
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: 71vert340] #2136860
08/19/16 09:41 PM
08/19/16 09:41 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
I just noticed from the first pic there is a visible difference in the glass bottom edge angle, so I'm sure it would affect how the glass sat in the window opening and I'm not sure you could adjust that out.
Terry
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2136875
08/19/16 09:52 PM
08/19/16 09:52 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Same here I see that the hard top mounting is @ more of an angle to the rear even though its not as parallel to the conv.one,as fare as the curve its hard to tell with all the hardware on but possibly different.
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2137309
08/20/16 03:46 PM
08/20/16 03:46 PM
Indianapolis, IN
Indianapolis, IN
Terry - Thank you very much for posting the pictures and your assessment of the two different styles. The pictures are worth a 1000 words.
I see what you mean that the back edge of the glass does have a big difference in its position, and the rear-most mounting hole (in your first picture) is in a higher position on the hardtop glass mounting bracket compared to the convertible. Since the mounting bracket has different part numbers, clearly there must be a difference large enough in the design of the hardtop vs. convertible models that they don’t interchange.
Looking at the angle of the top of the “T” is a good way to distinguish the 2 different styles.
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2137432
08/20/16 07:53 PM
08/20/16 07:53 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
Here's one additional pic that shows more differences in the two mounting brackets. The h/t bracket shows how much larger the glass is compared to the convertible glass. Also note the triangular web behind the top rear mount hole is larger in the convertible bracket. I've never compared the two even though they hang on the wall next to each other. The h/t has a part number of 3499648 and the convertible number is 3499646 for the two shown.
Terry
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2137813
08/21/16 12:41 PM
08/21/16 12:41 PM
Indianapolis, IN
Indianapolis, IN
Yes...I see exactly what you mean. I'm surprised the glass sizes are so different.
Thanks for the part numbers.
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: B5Cuda440-6] #2137986
08/21/16 04:35 PM
08/21/16 04:35 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Wow. Completely different glass shape.
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible [Re: A990] #2139777
08/24/16 09:38 AM
08/24/16 09:38 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Convertible E body quarter glass is convertible only, as is the mounting hardware. Convertible quarter glass is often confused with Cuda hardtop glass. The Challenger hardtop glass as shown in the pictures has a curved top edge and is much wider, but Cuda hardtop glass has the same shape with the flat edge where it meets the roof. Like the Challenger hardtop it too is much wider. Make sure if you are going to buy convertible E body quarter glass you make sure to measure it and make sure that you are getting convertible glass and not Cuda hardtop glass. Maybe you can get the measurements on the convertible glass from the member that posred the pictures in this thread.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
