70 E-Body Quarter Glass Hardtop vs. Convertible
#2135980
08/18/16 04:59 PM
08/18/16 04:59 PM
Posts: 567 Indianapolis, IN
B5Cuda440-6
Indianapolis, IN
Question about quarter glass:
Is the lower metal glass mounting structure and weather-strip/chrome-strip the same for both 70 E-Body hardtop and convertible models?
In other words, if I had a set of convertible quarter window assemblies, could I replace the glass with a hardtop glass, install them in my Cuda hardtop, and they would work?
The reference picture below is an NOS hardtop quarter window assembly that I found in another thread.
Thanks!
Re: 70 E-Body Quarter Glass Hardtop vs. Convertible
[Re: 71vert340]
#2136860
08/19/16 09:41 PM
08/19/16 09:41 PM
Posts: 674 Kennewick, Wa.
71vert340
Kennewick, Wa.
I just noticed from the first pic there is a visible difference in the glass bottom edge angle, so I'm sure it would affect how the glass sat in the window opening and I'm not sure you could adjust that out. Terry
[Re: A990]
#2139777
08/24/16 09:38 AM
08/24/16 09:38 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
Convertible E body quarter glass is convertible only, as is the mounting hardware. Convertible quarter glass is often confused with Cuda hardtop glass. The Challenger hardtop glass as shown in the pictures has a curved top edge and is much wider, but Cuda hardtop glass has the same shape with the flat edge where it meets the roof. Like the Challenger hardtop it too is much wider. Make sure if you are going to buy convertible E body quarter glass you make sure to measure it and make sure that you are getting convertible glass and not Cuda hardtop glass. Maybe you can get the measurements on the convertible glass from the member that posred the pictures in this thread.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
