Drop in solid roller lifters for stock block 440 #2129250
08/10/16 05:21 AM
08/10/16 05:21 AM
Burbank California
Joey Johnson Offline OP
Burbank California
Hi everyone. Who makes a real drop in solid roller lifter for a stock block 440? Cam is 650 lift and needs push rod fed rockers and pressure fed oiling of the wheels. Thanks!
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129327
08/10/16 11:31 AM
08/10/16 11:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Crane 66550. Best deal is from Moparts member "competitionwedge" in Syracuse, NY.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129390
08/10/16 12:41 PM
08/10/16 12:41 PM
AndyF Offline
AndyF  Offline
The AMC lifters from Comp Cams work and are fairly inexpensive. Comp mopar lifter on the left and AMC lifter on the right. The mopar lifter doesn't oil the roller or the pushrod while the AMC lifter does both.
Re: Drop in solid roller lifters for stock block 440 [Re: AndyF] #2129420
08/10/16 01:12 PM
08/10/16 01:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What about the cutaway bleeding off oil pressure..........the Red-Zones I first bought bleed off pressure from uncovering at max lift so I run the Isky solid bodies now w/zero issues..........
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129517
08/10/16 02:50 PM
08/10/16 02:50 PM
AndyF Offline
AndyF  Offline
There is a limit to how much lobe lift you can run with the cut away type lifters. I run 0.460 lobe lift in my 470 without any issues but it is getting close to the edge. I don't think you can run 0.500 lobe lift without bushing the lifter bores.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129524
08/10/16 02:58 PM
08/10/16 02:58 PM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
That AMC lifter looks nice. I use the mopar lifter on the left.
Re: Drop in solid roller lifters for stock block 440 [Re: AndyF] #2129541
08/10/16 03:17 PM
08/10/16 03:17 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The Red-Zones were uncovered w/my lowly .680-.660 cam enuff to only have 20-25 psi above 3000 rpm...........
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129726
08/10/16 07:17 PM
08/10/16 07:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The problem with those AMC lifters is around the wheel. Mopar lifters shroud one side of the lifter so it doesn't expose the oil galley. Those AMC lifters will bleed off oil like crazy in a stock block with lift .600 or higher. In fact, even those Mopar lifters in the photo don't have the wheel shrouded and will bleed of oil pressure.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2129737
08/10/16 07:32 PM
08/10/16 07:32 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Re: Drop in solid roller lifters for stock block 440 [Re: Thumperdart] #2129742
08/10/16 07:43 PM
08/10/16 07:43 PM
AndyF Offline
AndyF  Offline
Yes, I've seen problems with Crower and Isky roller lifters in stock blocks too. But the AMC lifters work just fine at .460 lobe lift in my stock block. The Crower lifters that I had a problem with had the oil hole drilled in the wrong location so maybe they have changed the design since then. It can be a little hit or miss with Mopar lifters......
Re: Drop in solid roller lifters for stock block 440 [Re: AndyF] #2129747
08/10/16 07:49 PM
08/10/16 07:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good to know............ thumbs
Re: Drop in solid roller lifters for stock block 440 [Re: AndyF] #2130085
08/11/16 03:09 AM
08/11/16 03:09 AM
Burbank California
Burbank California
My cam will be 405 lobe lift in a stock non bushed RB. It should be okay still right? Just worried as heck about which lifters to run and having them last. Andy have you tried those MRL performance lifters? I have your Big Block book too by the way, great read!! Has helped me a lot so far.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2130115
08/11/16 08:49 AM
08/11/16 08:49 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Isky Red Zones. 0.420 Lobe. Unbushed block. Standard oil pump. No problem.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2130234
08/11/16 12:27 PM
08/11/16 12:27 PM
AndyF Offline
AndyF  Offline
I haven't tried the MRL lifters. I think he buys Morel lifters and resells as his brand but I'm not 100% positive. Lots of people rebox the Morels and sell them under their own brand name.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2130282
08/11/16 01:22 PM
08/11/16 01:22 PM
an8sec70cuda Offline
I have Crane 66542-16 solid roller lifters in my stock 440 block. Has a .700" lift cam and no issues at all.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Drop in solid roller lifters for stock block 440 [Re: AndyF] #2130298
08/11/16 01:59 PM
08/11/16 01:59 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
MRL sells BAM Products lifters as his own
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2130344
08/11/16 03:14 PM
08/11/16 03:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Those do not indicate pushrod oiling.
Crane 66550 are the "Ultra-pro". Pushrod oiling, pressurized oil to the roller wheel, no mods to stock bores required.
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2130378
08/11/16 03:54 PM
08/11/16 03:54 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
BAM Products may make the lifters MRL sells. he may also have them changed somewhat. I bought a set from Mike and they came drop shipped from FL where BAM is.
More info: http://www.hughesengines.com/Upload/BAM_lifters/BAM.pdf
Re: Drop in solid roller lifters for stock block 440 [Re: Stanton] #2131016
08/12/16 12:33 PM
08/12/16 12:33 PM
Sorry, you're right. I completely missed the part about needing pushrod oiling in the OP's post.
CHIP
Re: Drop in solid roller lifters for stock block 440 [Re: Joey Johnson] #2131207
08/12/16 03:45 PM
08/12/16 03:45 PM
AndyF Offline
AndyF  Offline
Comp has a new sportsman lifter out which is $200 more than the entry level lifters and has the pushrod oiling feature. I haven't used these yet but they appear to be available:
https://www.summitracing.com/parts/cca-96829-16/overview/make/chrysler
