Re: Drop in solid roller lifters for stock block 440
[Re: AndyF]
#2129420
08/10/16 12:12 PM
08/10/16 12:12 PM
Thumperdart
State of confusion
What about the cutaway bleeding off oil pressure..........the Red-Zones I first bought bleed off pressure from uncovering at max lift so I run the Isky solid bodies now w/zero issues..........
[Re: AndyF]
#2129541
08/10/16 02:17 PM
08/10/16 02:17 PM
Thumperdart
State of confusion
There is a limit to how much lobe lift you can run with the cut away type lifters. I run 0.460 lobe lift in my 470 without any issues but it is getting close to the edge. I don't think you can run 0.500 lobe lift without bushing the lifter bores. The Red-Zones were uncovered w/my lowly .680-.660 cam enuff to only have 20-25 psi above 3000 rpm...........
[Re: Thumperdart]
#2129742
08/10/16 06:43 PM
08/10/16 06:43 PM
Posts: 31,344 Oregon
AndyF
There is a limit to how much lobe lift you can run with the cut away type lifters. I run 0.460 lobe lift in my 470 without any issues but it is getting close to the edge. I don't think you can run 0.500 lobe lift without bushing the lifter bores. The Red-Zones were uncovered w/my lowly .680-.660 cam enuff to only have 20-25 psi above 3000 rpm........... Yes, I've seen problems with Crower and Isky roller lifters in stock blocks too. But the AMC lifters work just fine at .460 lobe lift in my stock block. The Crower lifters that I had a problem with had the oil hole drilled in the wrong location so maybe they have changed the design since then. It can be a little hit or miss with Mopar lifters......
[Re: Joey Johnson]
#2130234
08/11/16 11:27 AM
08/11/16 11:27 AM
AndyF
My cam will be 405 lobe lift in a stock non bushed RB. It should be okay still right? Just worried as heck about which lifters to run and having them last. Andy have you tried those MRL performance lifters? I have your Big Block book too by the way, great read!! Has helped me a lot so far. I haven't tried the MRL lifters. I think he buys Morel lifters and resells as his brand but I'm not 100% positive. Lots of people rebox the Morels and sell them under their own brand name.
[Re: Joey Johnson]
#2130282
08/11/16 12:22 PM
08/11/16 12:22 PM
Posts: 13,651 Marion, South Carolina [><]
an8sec70cuda
I have Crane 66542-16 solid roller lifters in my stock 440 block. Has a .700" lift cam and no issues at all.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
[Re: AndyF]
#2130298
08/11/16 12:59 PM
08/11/16 12:59 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
I haven't tried the MRL lifters. I think he buys Morel lifters and resells as his brand but I'm not 100% positive. Lots of people rebox the Morels and sell them under their own brand name. MRL sells BAM Products lifters as his own
[Re: Joey Johnson]
#2130344
08/11/16 02:14 PM
08/11/16 02:14 PM
Posts: 9,237 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Crane 66542-16 solid roller lifters in my stock 440 block Those do not indicate pushrod oiling. Crane 66550 are the "Ultra-pro". Pushrod oiling, pressurized oil to the roller wheel, no mods to stock bores required.
[Re: Stanton]
#2131016
08/12/16 11:33 AM
08/12/16 11:33 AM
an8sec70cuda
Crane 66542-16 solid roller lifters in my stock 440 block Those do not indicate pushrod oiling. Crane 66550 are the "Ultra-pro". Pushrod oiling, pressurized oil to the roller wheel, no mods to stock bores required. Sorry, you're right. I completely missed the part about needing pushrod oiling in the OP's post.
