Re: engine balancing
[Re: DusterKid]
#2129484
08/10/16 02:20 PM
08/10/16 02:20 PM
RapidRobert
You have a serious machine. yes, & get a 318 (neutral) dampener. plus on the other end this will let you get/use a good aftermarket neutral converter & swap em later if ever needed.
[Re: DusterKid]
#2129486
08/10/16 02:21 PM
08/10/16 02:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Being a cast crank and the other things that would need to be changed.. damper and conv and the balancing cost... I dont think I would.. but if your buying a balancer and you can knock the weight off of the conv it would be up to you.. on all my forged and billet cranks I always go internal but I also turn way more rpm than you
[Re: B1MAXX]
#2129495
08/10/16 02:31 PM
08/10/16 02:31 PM
Posts: 1,986 Apollo, PA.
B1MAXX
Apollo, PA.
Last time I had this done it cost a little over 500 bucks. Probably not worth it. The other stock crank 360 apps I've messed with, just used the b&m plate, and external balancer with the neutral converter. Just to clarify the external still got sent out for balance job. Which was around 200 bucks.
[Re: DusterKid]
#2129612
08/10/16 04:51 PM
08/10/16 04:51 PM
Posts: 5,894 Florida
Locomotion
SRP pistons (at least flat-tops)and Scat I-beam rods are lighter than stock. You may not need as much Mallory metal, if any, as you may think using a neutral damper/balancer and flexplate!
[Re: DusterKid]
#2129630
08/10/16 05:14 PM
08/10/16 05:14 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I dont think this combination of rods/pistons will require any mallory metal.
BTW, using King rod bearings will knock quite a few grams off.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#2129712
08/10/16 06:48 PM
08/10/16 06:48 PM
KOS
BTW, using King rod bearings will knock quite a few grams off. i agree i built this combo years ago almost exactly the same and was easier to internal balance.........
