engine balancing #2129466
08/10/16 02:02 PM
08/10/16 02:02 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
I have a 360 assembly that I will be getting balanced. Stock crank, scat I beam rods, SRP pistons. The motor will be a street/strip with mostly strip, but will not see about 6500. Is it worth the extra money to have the assembly made internal vs external balanced?
Re: engine balancing [Re: DusterKid] #2129479
08/10/16 02:18 PM
08/10/16 02:18 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Last time I had this done it cost a little over 500 bucks. Probably not worth it. The other stock crank 360 apps I've messed with, just used the b&m plate, and external balancer with the neutral converter.
Re: engine balancing [Re: DusterKid] #2129484
08/10/16 02:20 PM
08/10/16 02:20 PM
You have a serious machine. yes, & get a 318 (neutral) dampener. plus on the other end this will let you get/use a good aftermarket neutral converter & swap em later if ever needed.
Re: engine balancing [Re: DusterKid] #2129486
08/10/16 02:21 PM
08/10/16 02:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Being a cast crank and the other things that
would need to be changed.. damper and conv and
the balancing cost... I dont think I would..
but if your buying a balancer and you can knock
the weight off of the conv it would be up to you..
on all my forged and billet cranks I always go internal
but I also turn way more rpm than you
wave
Re: engine balancing [Re: B1MAXX] #2129495
08/10/16 02:31 PM
08/10/16 02:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Just to clarify the external still got sent out for balance job. Which was around 200 bucks.
Re: engine balancing [Re: DusterKid] #2129612
08/10/16 04:51 PM
08/10/16 04:51 PM
Locomotion Offline
Locomotion  Offline
SRP pistons (at least flat-tops)and Scat I-beam rods are lighter than stock. You may not need as much Mallory metal, if any, as you may think using a neutral damper/balancer and flexplate!
Re: engine balancing [Re: DusterKid] #2129630
08/10/16 05:14 PM
08/10/16 05:14 PM
oberlin, Ohio
Rapid340 Online content
Rapid340  Online Content
oberlin, Ohio
I dont think this combination of rods/pistons will require any mallory metal.
BTW, using King rod bearings will knock quite a few grams off.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: engine balancing [Re: Rapid340] #2129712
08/10/16 06:48 PM
08/10/16 06:48 PM
K
KOS Offline
KOS  Offline
K
i agree i built this combo years ago almost exactly the same and was easier to internal balance.........
Re: engine balancing [Re: KOS] #2130450
08/11/16 05:48 PM
08/11/16 05:48 PM
dogdays Offline
dogdays  Offline
Agreed, those Scat rods are about 100 grams each lighter than the 645s, and the pistons should be around 100 grams lighter as well.
Shouldn't be too hard to do a test run with the new bobweights and see if it needs some extra weight added. If it does, then you can go to the external stock balance, but there'll be a lot of metal drilled out of the crank and if that's the case I'd suggest cutting down the counterweight OD.
Or if it's just a slug I'd think seriously about internal balancing.
Choices..........
R.
Re: engine balancing [Re: DusterKid] #2131550
08/12/16 10:36 PM
08/12/16 10:36 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
It takes about 2 minutes longer to spin it without the external weights on it and determine if it can be internally balanced without heavy metal.
I wouldn't bother putting heavy metal into a cast crank. At that point, it's time to put that money towards a forged crank. S/F....Ken M
