Re: Where's this wire go?
[Re: poly]
#212354
02/02/09 08:55 PM
02/02/09 08:55 PM
Posts: 1,978 USA
Suregrip391
USA
could it be a tach lead????
My car is equipped with a factory clock, no tach in the dash...(clock dont work) could it be a clock wire?
[Re: stumpy]
#212355
02/02/09 08:59 PM
02/02/09 08:59 PM
Posts: 1,978 USA
Suregrip391
USA
Have you checked to see if it is powered up with the key on. It kind of looks like the temp sending wire.
Key on is giving me 10 volts to that wire...Key off gives no power to it.
[Re: copchaser]
#212356
02/02/09 09:03 PM
02/02/09 09:03 PM
Posts: 1,978 USA
Suregrip391
USA
A/C compresser?
Nope, not the AC compressor, thats all hooked up and working, and I am able to trace that back to the firewall area.
[Re: 1_WILD_RT]
#212358
02/02/09 09:15 PM
02/02/09 09:15 PM
Posts: 1,978 USA
Suregrip391
USA
Plugged into the original style vacuum advance which would have two leads, one is power (that one) the other went to an idle ground lug on the carburator...
Interesting, so someone changed the distributor your thinking? and should have just capped off this wire?
[Re: Magnum]
#212362
02/03/09 12:04 AM
02/03/09 12:04 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
electric choke?
Electric choke is blue.
In 70 Chrysler wasn't using a choke heater yet, that started in I believe 72....
[Re: 1_WILD_RT]
#212363
02/03/09 05:15 AM
02/03/09 05:15 AM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
In 1970 some 383's & 440's (mostly HP)had a advance designed to drop all timing at idle, it looked like this...
Some cars that didn't get that style advance still have the connector taped into the harness.. That's probably what happened here..
Wow, learn something new everyday . So it has some kinda solenoid that's supposed to eliminate idle advance somehow? That's kinda what the timed port is for
[Re: 1_WILD_RT]
#212364
02/03/09 12:40 PM
02/03/09 12:40 PM
360six
electric choke?
Missed the '70 part, should have read the whole thing.
