Where's this wire go? #212349
02/02/09 08:50 PM
02/02/09 08:50 PM
USA
Suregrip391 Offline OP
USA
Sorry for the bad pics, I have this blueish colored wire that comes out of the wiring harness and does not seem to go anywhere? Not that I can see. It's in the center of the pics, it's wrapped up in the same harness as the coil wire is, It's also the same color as the coil wire. Where is it supposed to go? (Its the blueish colored insulated wire with the end broken off showing its copper wire at the end). Again, sorry for the bad pics! The car is a 70 B-body Satellite with a 383 and I cannot seem to trace it down in a wiring diagram.
Re: Where's this wire go? [Re: Suregrip391] #212350
02/02/09 08:51 PM
02/02/09 08:51 PM
USA
USA
second picture
Re: Where's this wire go? [Re: Suregrip391] #212351
02/02/09 08:52 PM
02/02/09 08:52 PM
iowa
copchaser Offline
copchaser  Offline
iowa
A/C compresser?
Re: Where's this wire go? [Re: Suregrip391] #212352
02/02/09 08:53 PM
02/02/09 08:53 PM
OMAHA
poly Offline
poly  Offline
OMAHA
could it be a tach lead????
Re: Where's this wire go? [Re: Suregrip391] #212353
02/02/09 08:54 PM
02/02/09 08:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked to see if it is powered up with the key on. It kind of looks like the temp sending wire.
Re: Where's this wire go? [Re: poly] #212354
02/02/09 08:55 PM
02/02/09 08:55 PM
USA
USA
My car is equipped with a factory clock, no tach in the dash...(clock dont work) could it be a clock wire?
Re: Where's this wire go? [Re: stumpy] #212355
02/02/09 08:59 PM
02/02/09 08:59 PM
USA
USA
Key on is giving me 10 volts to that wire...Key off gives no power to it.
Re: Where's this wire go? [Re: copchaser] #212356
02/02/09 09:03 PM
02/02/09 09:03 PM
USA
USA
A/C compresser?
Nope, not the AC compressor, thats all hooked up and working, and I am able to trace that back to the firewall area.
Re: Where's this wire go? [Re: Suregrip391] #212357
02/02/09 09:07 PM
02/02/09 09:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Plugged into the original style vacuum advance which would have two leads, one is power (that one) the other went to an idle ground lug on the carburator...
Re: Where's this wire go? [Re: 1_WILD_RT] #212358
02/02/09 09:15 PM
02/02/09 09:15 PM
USA
USA
Interesting, so someone changed the distributor your thinking? and should have just capped off this wire?
Re: Where's this wire go? [Re: Suregrip391] #212359
02/02/09 10:41 PM
02/02/09 10:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
In 1970 some 383's & 440's (mostly HP)had a advance designed to drop all timing at idle, it looked like this...
Some cars that didn't get that style advance still have the connector taped into the harness.. That's probably what happened here..
Re: Where's this wire go? [Re: 1_WILD_RT] #212360
02/02/09 10:55 PM
02/02/09 10:55 PM
3
360six Offline
360six  Offline
electric choke?
Re: Where's this wire go? [Re: 360six] #212361
02/02/09 11:46 PM
02/02/09 11:46 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
electric choke?
Electric choke is blue.
Re: Where's this wire go? [Re: Magnum] #212362
02/03/09 12:04 AM
02/03/09 12:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
electric choke?
In 70 Chrysler wasn't using a choke heater yet, that started in I believe 72....
Re: Where's this wire go? [Re: 1_WILD_RT] #212363
02/03/09 05:15 AM
02/03/09 05:15 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Wow, learn something new everyday . So it has some kinda solenoid that's supposed to eliminate idle advance somehow? That's kinda what the timed port is for
Re: Where's this wire go? [Re: 1_WILD_RT] #212364
02/03/09 12:40 PM
02/03/09 12:40 PM
3
360six Offline
360six  Offline
electric choke?
Missed the '70 part, should have read the whole thing.
