What the difference between 15x7 trim rings Mopar vs Olds #2109727
07/14/16 12:44 AM
07/14/16 12:44 AM
St. Paul, MN
stat5 Offline OP
stat5  Offline OP
St. Paul, MN
Looking for a trim expert, this is regarding the 15x7 3" deep trim rings.
I heard the Oldsmobile 15x7 trim ring is similar in appearance to the Mopar 15x7 trim ring.
My question is how can one tell them apart?
Thanks for any answers?
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: stat5] #2110002
07/14/16 05:04 PM
07/14/16 05:04 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I thought Olds used Polished trim rings, with Mopar polished 70-71 Brushed 72.
Ron
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: stat5] #2110003
07/14/16 05:05 PM
07/14/16 05:05 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i think its the opening for the valve stem is different
nobody has a dead nuts repo for that ring
i have a set of olds rings i'm using on a driver i'm building
for the money, i won't care if they get beat up or not.
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: flypaper] #2110063
07/14/16 06:50 PM
07/14/16 06:50 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Dremel tool to oval out that stem opening. wink
I've seen the olds rings mentioned on here last time the trim ring subject came up. No further details given, so I'm glad this question was asked, thanks OP. up
To add to the original question: I'd like to see the difference in the olds ring vs whatever ring Vintage Wheels or whoever gives you when you get a set? Photos? shruggy
Mo' Farts
Moderated by "tbagger".
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: stat5] #2110082
07/14/16 07:29 PM
07/14/16 07:29 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Probably if one were to Google images of them, you'd see if there was much difference.
I seem to recall that the Chevy/Vette rings had the valve stem located differently, but no too far.
Other factors could be if mounting clips were in the same place, and what size the inner opening is, but both might be OK.
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: topside] #2110127
07/14/16 08:53 PM
07/14/16 08:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ahhh...this is Moparts, most on here are like.....
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: DAYCLONA] #2110155
07/14/16 10:10 PM
07/14/16 10:10 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Don't yopu love how the Mopar stuff is always more $$$$$$$$$
Ron
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: stat5] #2112553
07/18/16 04:32 PM
07/18/16 04:32 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
Those Mopar trim rings do not look OE correct to me.
Ask Terry McCann if you want the scoop.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: What the difference between 15x7 trim rings Mopar vs Olds [Re: stat5] #2113064
07/19/16 08:33 AM
07/19/16 08:33 AM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
wow i have a set of the olds trim rings never even thought they would work on my mopar rims.so the only difference is the valve stem opening?
