Re: What the difference between 15x7 trim rings Mopar vs Olds
[Re: flypaper]
#2110063
07/14/16 06:50 PM
07/14/16 06:50 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
i think its the opening for the valve stem is different nobody has a dead nuts repo for that ring i have a set of olds rings i'm using on a driver i'm building for the money, i won't care if they get beat up or not. Dremel tool to oval out that stem opening. I've seen the olds rings mentioned on here last time the trim ring subject came up. No further details given, so I'm glad this question was asked, thanks OP. To add to the original question: I'd like to see the difference in the olds ring vs whatever ring Vintage Wheels or whoever gives you when you get a set? Photos?
Mo' Farts
Moderated by "tbagger".
[Re: topside]
#2110127
07/14/16 08:53 PM
07/14/16 08:53 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Probably if one were to Google images of them, you'd see if there was much difference. Ahhh...this is Moparts, most on here are like.....
[Re: DAYCLONA]
#2110155
07/14/16 10:10 PM
07/14/16 10:10 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Probably if one were to Google images of them, you'd see if there was much difference. Ahhh...this is Moparts, most on here are like..... Don't yopu love how the Mopar stuff is always more $$$$$$$$$ Ron
[Re: stat5]
#2112553
07/18/16 04:32 PM
07/18/16 04:32 PM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
Those Mopar trim rings do not look OE correct to me. Ask Terry McCann if you want the scoop.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
