Drag slck to frame rail clearance? #2110882
07/15/16 11:25 PM
07/15/16 11:25 PM
Illinois
Mopar_Ray Offline OP
Illinois
I am going to run some MT 29.5/10.5-15W slicks soon. I have about 5/8" clearance from tire to frame rail (Springs moved inside frame) Is that enough?
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110886
07/15/16 11:33 PM
07/15/16 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats on the minimum side but should clear..
but since its on the frame side you shouldnt
have any sharp edges like out on the fender
side.. might rub on quicker cornering
wave
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110895
07/15/16 11:57 PM
07/15/16 11:57 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I run 1/2" for 3 years, no issue.
Doug
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110906
07/16/16 12:12 AM
07/16/16 12:12 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
5/8" should be fine.
[image][/image]
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110907
07/16/16 12:13 AM
07/16/16 12:13 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
It'll be fine.
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110921
07/16/16 12:25 AM
07/16/16 12:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Another factor you have to deal with is the
tire size to the rim size and the pressure..
but from what the others are saying it wont
rub on cornering
EDIT
also another factor... bias ply or radials..
a radial will have less movement due to higher
pressures over the bias ply
wave
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2110971
07/16/16 03:11 AM
07/16/16 03:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Drag only car you will be fine
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2111037
07/16/16 10:49 AM
07/16/16 10:49 AM
Illinois
Illinois
Just thinking out loud... Would a 1/4" spacer be ok, drag racing?
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2111058
07/16/16 11:35 AM
07/16/16 11:35 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've never had an issue with Spacers. My 11.0 street car has 1/4". My 9.0 drag car has 1/8". The trick is to make sure the wheel lugs are properly torqued. I use 100 lb/ft on 1/2" studs.
Doug
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2112243
07/18/16 03:26 AM
07/18/16 03:26 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Spacer is not an issue. We have cars that run NA 10.5 that have 3-4" spacers. Those guys normally run Comp with more tire. Funny thing is they are faster NA 10.5 racing...Yet still put the big ones back on...
Re: Drag slck to frame rail clearance? [Re: Mopar_Ray] #2112456
07/18/16 02:09 PM
07/18/16 02:09 PM
Slow the car way down before doing the turns on and off the track thumbsI've had more than one car with 1/2 inch on bias tires, go slow when in doubt on the turns up
