Re: Fastest Thermoquad?
[Re: POZEST]
#209580
01/31/09 05:30 PM
01/31/09 05:30 PM
Posts: 5,160 Texas
dannysbee
Texas
Steve Wann's 74 E/SA Dart runs 10.80's with one. There is a SS F body out of Louisiana that runs in the 9's I believe. Of coarse both of these would be small blocks.
Getting old just means you were smarter than some and luckier than others.
[Re: prochamp]
#209582
01/31/09 07:39 PM
01/31/09 07:39 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
all your small mopars in SS/IA and slower along with GT classes will be using a thermoquad...these would be 71 and newer engines also.
dont think a small block fits into SS/F class..
they probably only use them because they have too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: HotRodDave]
#209584
02/01/09 12:21 AM
02/01/09 12:21 AM
70AARcuda
las vegas
yes..and that is why i said 71 and new combos...
Tony
[Re: sixpakdodge]
#209592
02/01/09 03:57 AM
02/01/09 03:57 AM
Posts: 30,490 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
The Competition TQ .. if you can find it. But other than that ... a good early one -- say off of a motorhome or truck. NO NEED for some high $$$ parts ... just get a service manual and some hi-po tech articles from some past monthly magazines. PLUS ... you will need that new and improved air-valve tool ! ....
[Re: dOc …]
#209593
02/01/09 09:33 AM
02/01/09 09:33 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I've always run thermoquads. In my opinion they are the most advanced 4 BBL carb ever used on a production vehicle. The basic design was done in the sixties. Carter engineers were way ahead of their time using a composite bowl to insulate fuel and teflon coatings on the shafts. They metered fuel so well they were one of only a few 4bbl OEM choices in the smog/emissions era. You can set up an 850 thermoquad to run on a 318 without any problem. Extremely versatile carb for the flow.
Another interesting aspect is weight. Next time you get a chance pick up a thermoquad in one hand and a holley 4 bbl in the other. There are a lot of guys that took off their production cast iron TQ induction setup going to an aluminum intake and holley carb thinking they were going to save a bunch of weight.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Hot 340]
#209595
02/01/09 10:15 AM
02/01/09 10:15 AM
dOc …
Florida STAYcation
Ive seen them on a small block superstock Sebring car running 10 oh's with one. I went over and talked to the guys running it, and said they'd do anything to be allowed to bolt on a holley in it's place. NOt trying to , it's just what the guy said.
Very interesting ...and yes I believe that it has been said more than once.
BUTTTT don't you think a SS class racer would actually KNOW how much a Holley is "worth" over a TQ if he was making such a statement ?
[Re: dOc …]
#209598
02/01/09 10:26 AM
02/01/09 10:26 AM
Posts: 20,213 Park Forest, IL
slantzilla
Park Forest, IL
The biggest drawback to a TQ that I have seen anyone actually prove through testing on a big block was small fuel bowl capacity. A buddy and I did back-to-back-to-back testing between a self modified 800 QJ, a Kenne-Bell 1000 TQ, and an 850 Holley on an 11 second 455 Buick GS. The TQ ran about the same as the QJ and the Holley was .3 and 2MPH faster. Same car, same day. Yes, we had every available jet, needle, and needle/seat combo and just couldn't get enough fuel into either the TQ or QJ to make up the difference. Of the three, my favorite was the QJ for simplicity and ease of adjustment.
