Page 1 of 3 1 2 3
Fastest Thermoquad? #209579
01/31/09 05:03 PM
01/31/09 05:03 PM
Hamilton,Ohio
P
POZEST Offline OP
POZEST  Offline OP
P
Hamilton,Ohio
What is the fastest car that you have seen running a thermoquad? Big block, smallblock, doesn't mater.
Re: Fastest Thermoquad? [Re: POZEST] #209580
01/31/09 05:30 PM
01/31/09 05:30 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Steve Wann's 74 E/SA Dart runs 10.80's with one. There is a SS F body out of Louisiana that runs in the 9's I believe. Of coarse both of these would be small blocks.
Getting old just means you were smarter than some and luckier than others.
Re: Fastest Thermoquad? [Re: POZEST] #209581
01/31/09 06:53 PM
01/31/09 06:53 PM
ohio
prochamp Offline
prochamp  Offline
ohio
i ran 10.16 with one 345 inch w2 motor.mike wethington ran 10.07 last season in his 365 inch w2 lebaron.
Re: Fastest Thermoquad? [Re: prochamp] #209582
01/31/09 07:39 PM
01/31/09 07:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
all your small mopars in SS/IA and slower along with GT classes will be using a thermoquad...these would be 71 and newer engines also.
dont think a small block fits into SS/F class..
they probably only use them because they have too...
Tony
70 AARCuda Vitamin C
Re: Fastest Thermoquad? [Re: 70AARcuda] #209583
01/31/09 11:49 PM
01/31/09 11:49 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
They don't have to run a thermoquad, they could run the older 340 car and an AVS so there is some choice there and see whitch one they choose
Re: Fastest Thermoquad? [Re: HotRodDave] #209584
02/01/09 12:21 AM
02/01/09 12:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..and that is why i said 71 and new combos...
Tony
Re: Fastest Thermoquad? [Re: 70AARcuda] #209585
02/01/09 12:30 AM
02/01/09 12:30 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I was just saying they choose the 71+ engines "because" of the thermo quad not "in spite" of it. Not trying to
Re: Fastest Thermoquad? [Re: HotRodDave] #209586
02/01/09 12:31 AM
02/01/09 12:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ok...
Tony
Re: Fastest Thermoquad? [Re: HotRodDave] #209587
02/01/09 12:49 AM
02/01/09 12:49 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
There's a reason NHRA factors the 71 340 higher than the 70......
Re: Fastest Thermoquad? [Re: Kevins493] #209588
02/01/09 02:08 AM
02/01/09 02:08 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Is this on a T-shirt in-order ?
Re: Fastest Thermoquad? [Re: dOc !] #209589
02/01/09 02:45 AM
02/01/09 02:45 AM
near Harrisburg, Pa
440trk Offline
440trk  Offline
near Harrisburg, Pa
Why of course, silly.
Re: Fastest Thermoquad? [Re: 440trk] #209590
02/01/09 03:11 AM
02/01/09 03:11 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Well TRKer ... WHICH ONE of us .. should do-it ?
Re: Fastest Thermoquad? [Re: dOc !] #209591
02/01/09 03:20 AM
02/01/09 03:20 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
What is the best thermoquad to prepare for race use?
Re: Fastest Thermoquad? [Re: sixpakdodge] #209592
02/01/09 03:57 AM
02/01/09 03:57 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
The Competition TQ .. if you can find it. But other than that ... a good early one -- say off of a motorhome or truck.
NO NEED for some high $$$ parts ... just get a service manual and some hi-po tech articles from some past monthly magazines.
PLUS ... you will need that new and improved air-valve tool ! ....
Re: Fastest Thermoquad? [Re: dOc !] #209593
02/01/09 09:33 AM
02/01/09 09:33 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I've always run thermoquads. In my opinion they are the most advanced 4 BBL carb ever used on a production vehicle. The basic design was done in the sixties. Carter engineers were way ahead of their time using a composite bowl to insulate fuel and teflon coatings on the shafts. They metered fuel so well they were one of only a few 4bbl OEM choices in the smog/emissions era. You can set up an 850 thermoquad to run on a 318 without any problem. Extremely versatile carb for the flow.
Another interesting aspect is weight. Next time you get a chance pick up a thermoquad in one hand and a holley 4 bbl in the other. There are a lot of guys that took off their production cast iron TQ induction setup going to an aluminum intake and holley carb thinking they were going to save a bunch of weight.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Fastest Thermoquad? [Re: POZEST] #209594
02/01/09 09:41 AM
02/01/09 09:41 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Ive seen them on a small block superstock Sebring car running 10 oh's with one. I went over and talked to the guys running it, and said they'd do anything to be allowed to bolt on a holley in it's place. NOt trying to , it's just what the guy said.
Re: Fastest Thermoquad? [Re: Hot 340] #209595
02/01/09 10:15 AM
02/01/09 10:15 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Very interesting ...and yes I believe that it has been said more than once.
BUTTTT don't you think a SS class racer would actually KNOW how much a Holley is "worth" over a TQ if he was making such a statement ?
Re: Fastest Thermoquad? [Re: dOc !] #209596
02/01/09 10:19 AM
02/01/09 10:19 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
INTERESTING statement ...and yes I believe that it has been said more than once.
BUTTTT don't you think a SS class racer would actually KNOW how much a Holley is "worth" over a TQ ?
He never said he didnt know..and it might not be worth anything et or mph wise... might just not like going through the hassle of making one work...
Re: Fastest Thermoquad? [Re: Hot 340] #209597
02/01/09 10:23 AM
02/01/09 10:23 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
OK .. but why would he say something like this without being specific ? .. and maybe he did not know how to tweak a TQ.
Was this guy competitive in SS ?
Re: Fastest Thermoquad? [Re: dOc !] #209598
02/01/09 10:26 AM
02/01/09 10:26 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
The biggest drawback to a TQ that I have seen anyone actually prove through testing on a big block was small fuel bowl capacity.
A buddy and I did back-to-back-to-back testing between a self modified 800 QJ, a Kenne-Bell 1000 TQ, and an 850 Holley on an 11 second 455 Buick GS. The TQ ran about the same as the QJ and the Holley was .3 and 2MPH faster. Same car, same day.
Yes, we had every available jet, needle, and needle/seat combo and just couldn't get enough fuel into either the TQ or QJ to make up the difference.
Of the three, my favorite was the QJ for simplicity and ease of adjustment.
Page 1 of 3 1 2 3
