Where to get a longer Battery Cable for Mini Starter? #1904248
09/01/15 05:39 PM
09/01/15 05:39 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Since I put TTI's on my engine I went with a Mini starter. The mini starter causes you to spin the cable around to attach it, this in-turn makes the cable's effective length shorter.
What cable could I use to get that length back so I can secure the Battery cable to fenderwell and not have to go over the steering shaft as pictured??? 1972 Satellite with 400.
Thanks Ron
Re: Where to get a longer Battery Cable for Mini Starter? [Re: RJS] #1904253
09/01/15 05:53 PM
09/01/15 05:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wouldn't it be easier to get a longer positive battery cable, available at any parts store, and move the starter relay closer to the starter?
Re: Where to get a longer Battery Cable for Mini Starter? [Re: stumpy] #1904268
09/01/15 06:11 PM
09/01/15 06:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
haha
you must be new here ...
Re: Where to get a longer Battery Cable for Mini Starter? [Re: RJS] #1904338
09/01/15 07:45 PM
09/01/15 07:45 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
A 71-72 B-body small block positive battery cable is about 6"-7" longer than the big-block version.
Re: Where to get a longer Battery Cable for Mini Starter? [Re: JohnRR] #1904492
09/01/15 10:25 PM
09/01/15 10:25 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
haha
John knows me well, I wouldn't move my relay and I hate to use a generic cable. The small block one suggested may work will have to do some measuring.
Any other thoughts?
Ron
Re: Where to get a longer Battery Cable for Mini Starter? [Re: RJS] #1904533
09/01/15 11:10 PM
09/01/15 11:10 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Not a lot of options with Hooker's...
I fabbed a bracket to keep it away from the tubes...
Re: Where to get a longer Battery Cable for Mini Starter? [Re: rick@laysons] #1904607
09/02/15 12:28 AM
09/02/15 12:28 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
What he said
Done it on a few cars with great results
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Where to get a longer Battery Cable for Mini Starter? [Re: bee1971] #1904766
09/02/15 11:36 AM
09/02/15 11:36 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Very good to know, any pictures to show.
Ron
Re: Where to get a longer Battery Cable for Mini Starter? [Re: rick@laysons] #1904768
09/02/15 11:37 AM
09/02/15 11:37 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Rick thanks for this information!!!
Ron
Re: Where to get a longer Battery Cable for Mini Starter? [Re: RJS] #2085600
06/03/16 10:59 PM
06/03/16 10:59 PM
None
71rm23 Offline
71rm23  Offline
None
P/N 3764166
Re: Where to get a longer Battery Cable for Mini Starter? [Re: 71rm23] #2085735
06/04/16 08:11 AM
06/04/16 08:11 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Originally Posted By 71rm23
P/N 3764166
Awesome .. Great idea
I saved this part number , i needed one yesterday .. Dammik.
Wish i too . ould get a small block Hemi cable . Lol ..
I need a part number ..
Re: Where to get a longer Battery Cable for Mini Starter? [Re: sogtx] #2085743
06/04/16 09:18 AM
06/04/16 09:18 AM
IN
ahy Offline
ahy  Offline
IN
Pretty straightforward to make what you need. NAPA carries the heavy cable, ends and shrink wrap. Measure, crimp, solder and shrink wrap makes a durable and neat looking cable.
Re: Where to get a longer Battery Cable for Mini Starter? [Re: ahy] #2085858
06/04/16 02:28 PM
06/04/16 02:28 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
On my '63 B, I ran the cable to the front of the engine and down and behind the motor mount and header. Much cleaner if you haeve the room. Not necessarily a stock look but the dipstick and motor mount aid in keeping it up against the block and away from the header.
'63 Dodge 330
11.19 @ 121 mph
Re: Where to get a longer Battery Cable for Mini Starter? [Re: RJS] #2085872
06/04/16 03:21 PM
06/04/16 03:21 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
If you're going to fabricate one to resemble your stock part, use ultrafine welding cable, it's better. S/F...Ken M
