Where to get a longer Battery Cable for Mini Starter?
#1904248
09/01/15 05:39 PM
09/01/15 05:39 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Since I put TTI's on my engine I went with a Mini starter. The mini starter causes you to spin the cable around to attach it, this in-turn makes the cable's effective length shorter. What cable could I use to get that length back so I can secure the Battery cable to fenderwell and not have to go over the steering shaft as pictured??? 1972 Satellite with 400. Thanks Ron
Re: Where to get a longer Battery Cable for Mini Starter?
[Re: stumpy]
#1904268
09/01/15 06:11 PM
09/01/15 06:11 PM
Posts: 75,088 A Banana Republic near you.
JohnRR
Wouldn't it be easier to get a longer positive battery cable, available at any parts store, and move the starter relay closer to the starter? you must be new here ...
[Re: JohnRR]
#1904492
09/01/15 10:25 PM
09/01/15 10:25 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Wouldn't it be easier to get a longer positive battery cable, available at any parts store, and move the starter relay closer to the starter? you must be new here ... John knows me well, I wouldn't move my relay and I hate to use a generic cable. The small block one suggested may work will have to do some measuring. Any other thoughts? Ron
[Re: rick@laysons]
#1904607
09/02/15 12:28 AM
09/02/15 12:28 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
A 71-72 B-body small block positive battery cable is about 6"-7" longer than the big-block version. What he said Done it on a few cars with great results
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#1904766
09/02/15 11:36 AM
09/02/15 11:36 AM
Posts: 6,224 JERSEY
RJS
JERSEY
A 71-72 B-body small block positive battery cable is about 6"-7" longer than the big-block version. What he said Done it on a few cars with great results Very good to know, any pictures to show. Ron
[Re: rick@laysons]
#1904768
09/02/15 11:37 AM
09/02/15 11:37 AM
Posts: 6,224 JERSEY
RJS
JERSEY
A 71-72 B-body small block positive battery cable is about 6"-7" longer than the big-block version. Rick thanks for this information!!! Ron
[Re: RJS]
#2085600
06/03/16 10:59 PM
06/03/16 10:59 PM
Posts: 2,592 None
71rm23
None
[Re: 71rm23]
#2085735
06/04/16 08:11 AM
06/04/16 08:11 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
Awesome .. Great idea I saved this part number , i needed one yesterday .. Dammik. Wish i too . ould get a small block Hemi cable . Lol .. I need a part number ..
[Re: ahy]
#2085858
06/04/16 02:28 PM
06/04/16 02:28 PM
Posts: 4,699 Wichita
GY3
Wichita
On my '63 B, I ran the cable to the front of the engine and down and behind the motor mount and header. Much cleaner if you haeve the room. Not necessarily a stock look but the dipstick and motor mount aid in keeping it up against the block and away from the header.
