X head to 1979 360 EH1 swap worth it? #2084742
06/02/16 06:20 PM
06/02/16 06:20 PM
Houston, Texas
racerx20 Offline OP
Standard but OK
racerx20  Offline OP
Standard but OK
Houston, Texas
Would swapping a set of 1969 X heads onto my stock (other than Edelbrock intake) 79 LRE 360 be worth it? From an old Hot Rod article it looks like the X's flowed ~221 @ .500 and the stock 79 360 heads did ~192 @ .500. Figured with the higher flow and larger valves it'd wake it up a bit. Would pair them with a nice street cam.
1972 Road Runner
1988 Shelby CSX-T
Re: X head to 1979 360 EH1 swap worth it? [Re: racerx20] #2084755
06/02/16 06:38 PM
06/02/16 06:38 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Worth it? That's up to you. Doubt you'd ever feel the difference.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: X head to 1979 360 EH1 swap worth it? [Re: racerx20] #2084833
06/02/16 09:02 PM
06/02/16 09:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Stock 1979 short block and street cam? Nope. rebuilding with high compression and big cam then maybe. Save your effort.
Re: X head to 1979 360 EH1 swap worth it? [Re: NANKET] #2084880
06/02/16 10:31 PM
06/02/16 10:31 PM
X3 you would not be happy after that outlay of time/money/effort
Re: X head to 1979 360 EH1 swap worth it? [Re: racerx20] #2085215
06/03/16 01:47 PM
06/03/16 01:47 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
On a stock motor the bigger valves might even kill some low end.
Re: X head to 1979 360 EH1 swap worth it? [Re: slantzilla] #2085525
06/03/16 09:11 PM
06/03/16 09:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Not onlky on a stock type engine. I tried going to a 2.02 set over my 1.88 heads on my mid t low 11 second Duster. Lost sixty foot but gained on top so it about equaled out. More consistent with the smaller valve head. Know dirt tracers that use the small valve head for more torque out of the turns.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
