X head to 1979 360 EH1 swap worth it?
#2084742
06/02/16 06:20 PM
06/02/16 06:20 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Would swapping a set of 1969 X heads onto my stock (other than Edelbrock intake) 79 LRE 360 be worth it? From an old Hot Rod article it looks like the X's flowed ~221 @ .500 and the stock 79 360 heads did ~192 @ .500. Figured with the higher flow and larger valves it'd wake it up a bit. Would pair them with a nice street cam.
1972 Road Runner
1988 Shelby CSX-T
Re: X head to 1979 360 EH1 swap worth it?
[Re: racerx20]
#2084755
06/02/16 06:38 PM
06/02/16 06:38 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Worth it? That's up to you. Doubt you'd ever feel the difference.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: NANKET]
#2084880
06/02/16 10:31 PM
06/02/16 10:31 PM
RapidRobert
X3 you would not be happy after that outlay of time/money/effort
[Re: racerx20]
#2085215
06/03/16 01:47 PM
06/03/16 01:47 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
On a stock motor the bigger valves might even kill some low end.
[Re: slantzilla]
#2085525
06/03/16 09:11 PM
06/03/16 09:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not onlky on a stock type engine. I tried going to a 2.02 set over my 1.88 heads on my mid t low 11 second Duster. Lost sixty foot but gained on top so it about equaled out. More consistent with the smaller valve head. Know dirt tracers that use the small valve head for more torque out of the turns.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
