Page 1 of 3 1 2 3
New cam or ? #2078040
05/22/16 12:48 AM
05/22/16 12:48 AM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
Looking to pick up a couple tenths,current set up is 69 runner with 470,Indy SR's max wedge from Dwayne Porter,matching intake 4150 with 1050 Dom. with Thumper treatment . Current cam was picked by Dwayne it's a comp soild flat tappet 615 lift,dur@50 266 intake and 270 exhaust .410 lobe lift ground on 110 put in at 106
8 in ultimate convertor 5000 ish stall 410 gear 28 in tall tire ,cal tracs
Car ran best of 10.40 @128,would like to get in 10 teens to 10 o's
Don't really want to do roller thing becuz put on about 2,000 street miles a year,thought maybe a little more cam or maybe just change rockers to 1.6 from 1.5
Just looking for thoughts car is in paint shop and engine is just sitting on stand so mind has been working LOL
Thanks EDDIE B
Re: New cam or ? [Re: EDDIEB] #2078043
05/22/16 12:56 AM
05/22/16 12:56 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Drop a 100lbs.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: New cam or ? [Re: EDDIEB] #2078185
05/22/16 12:11 PM
05/22/16 12:11 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
. bump
Re: New cam or ? [Re: EDDIEB] #2078186
05/22/16 12:13 PM
05/22/16 12:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
CR?
60 ft?
I wouldn't expect a big gain from a cam swap, but you could try 1.6s (only on the intakes since you already have more exhaust duration) to look for a small gain.
Do you have a hood scoop? If so, is the carb sealed to the scoop?
Exhaust system? Do you run open headers?
Re: New cam or ? [Re: BradH] #2078197
05/22/16 12:31 PM
05/22/16 12:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Originally Posted By BradH
CR?
60 ft?
iagree is your chassis working right... the 60'
will tell you how well it is.. if you run exhaust there
are muffs that just plain dont work well.... but your
looking for .3-.4..thats a fair amount
wave
Re: New cam or ? [Re: EDDIEB] #2078198
05/22/16 12:33 PM
05/22/16 12:33 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't see any major gains, if any, by swapping to another solid cam. Roller would be your next step. Indy heads can handle a lot more than .615" lift, so 1.6 rockers would be a plus on the top end charge. After that, I agree with others. Weight reduction, headers? compression?
[image][/image]
Re: New cam or ? [Re: BradH] #2078416
05/22/16 07:50 PM
05/22/16 07:50 PM
BradH Offline
BradH  Offline
CR?
60 ft?
Let me also ask what the converter slippage % is, the 1/8 mile ET & MPH, and the RPM going thru the traps in the 1/4...
Re: New cam or ? [Re: EDDIEB] #2078451
05/22/16 09:26 PM
05/22/16 09:26 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
it has 12.1 comp ,it 60 ft poor 1.50 to 1.48, 1/8 low 6.60's at 102-103 goes through 1/4@ 6800 ish
have a six pack scoop sealed and run open headers
Re: New cam or ? [Re: EDDIEB] #2078453
05/22/16 09:27 PM
05/22/16 09:27 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
also has tti step headers 2in to 2 1/8 in 3 1/2 collector
Re: New cam or ? [Re: EDDIEB] #2078473
05/22/16 10:08 PM
05/22/16 10:08 PM
BradH Offline
BradH  Offline
Do you have collector extensions bolted on the headers? On a car like yours, I'd expect it would "like" about an 18" extension.
Your 60 ft is soft... how much tuning have you done with suspension, carburetor, launch & shift RPM, etc.?
Re: New cam or ? [Re: EDDIEB] #2078482
05/22/16 10:40 PM
05/22/16 10:40 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
ran extensions and saw no gains ,different carb no gains,put trans brake in no change,it drives me nuts ,restall convertor no change just thinking I am missing something
Re: New cam or ? [Re: EDDIEB] #2078488
05/22/16 10:49 PM
05/22/16 10:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Like we talked, something is definitely goin on and the 60ft to me is where everything starts and needs to be fully rockin by the 330 then of course enuff fuel system to keep it charging forward. Is it spinning? Any video?
Re: New cam or ? [Re: EDDIEB] #2078489
05/22/16 10:50 PM
05/22/16 10:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your missing something with all those changes
and didnt change your ET
wave
Re: New cam or ? [Re: EDDIEB] #2078490
05/22/16 10:50 PM
05/22/16 10:50 PM
sgcuda Offline
sgcuda  Offline
Check rpm that full timing advance is in. Maybe you have a late curve.
[image][/image]
Re: New cam or ? [Re: sgcuda] #2078502
05/22/16 11:05 PM
05/22/16 11:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Have you checked for full throttle? Been there...........
Re: New cam or ? [Re: EDDIEB] #2078505
05/22/16 11:07 PM
05/22/16 11:07 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
timing is locked out,
Re: New cam or ? [Re: EDDIEB] #2078509
05/22/16 11:11 PM
05/22/16 11:11 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
has full throttle,maybe need to check fuel pressure at wot just have car in paint now and engine out that why was thing of cam change ,but not gonna do if not worth the effort
Re: New cam or ? [Re: EDDIEB] #2078510
05/22/16 11:13 PM
05/22/16 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you go to Ubly..if so we might be there next
month
wave
Re: New cam or ? [Re: EDDIEB] #2078512
05/22/16 11:16 PM
05/22/16 11:16 PM
BradH Offline
BradH  Offline
So, all those changes and it ran 10.4s at 128, regardless?
That makes no sense... and a cam change isn't going to "fix" it, unless you've also wiped it and don't know it, yet.
Re: New cam or ? [Re: EDDIEB] #2078515
05/22/16 11:24 PM
05/22/16 11:24 PM
Bad Axe,MI
E
EDDIEB Offline OP
EDDIEB  Offline OP
E
Bad Axe,MI
Mr P. I do go to Ubly ,but car is getting painted now so can't try anything now
Yes Brad,makes no sense it has run with in .05 with the changes,aimost which it would even slow down
Page 1 of 3 1 2 3
