New cam or ?
#2078040
05/22/16 12:48 AM
05/22/16 12:48 AM
Posts: 184 Bad Axe,MI
EDDIEB
Bad Axe,MI
Looking to pick up a couple tenths,current set up is 69 runner with 470,Indy SR's max wedge from Dwayne Porter,matching intake 4150 with 1050 Dom. with Thumper treatment . Current cam was picked by Dwayne it's a comp soild flat tappet 615 lift,dur@50 266 intake and 270 exhaust .410 lobe lift ground on 110 put in at 106 8 in ultimate convertor 5000 ish stall 410 gear 28 in tall tire ,cal tracs Car ran best of 10.40 @128,would like to get in 10 teens to 10 o's Don't really want to do roller thing becuz put on about 2,000 street miles a year,thought maybe a little more cam or maybe just change rockers to 1.6 from 1.5 Just looking for thoughts car is in paint shop and engine is just sitting on stand so mind has been working LOL Thanks EDDIE B
Re: New cam or ?
[Re: BradH]
#2078197
05/22/16 12:31 PM
05/22/16 12:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
CR?
60 ft?
I wouldn't expect a big gain from a cam swap, but you could try 1.6s (only on the intakes since you already have more exhaust duration) to look for a small gain.
Do you have a hood scoop? If so, is the carb sealed to the scoop?
Exhaust system? Do you run open headers? is your chassis working right... the 60' will tell you how well it is.. if you run exhaust there are muffs that just plain dont work well.... but your looking for .3-.4..thats a fair amount
Re: New cam or ?
[Re: EDDIEB]
#2078198
05/22/16 12:33 PM
05/22/16 12:33 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I don't see any major gains, if any, by swapping to another solid cam. Roller would be your next step. Indy heads can handle a lot more than .615" lift, so 1.6 rockers would be a plus on the top end charge. After that, I agree with others. Weight reduction, headers? compression?
[image][/image]
Re: New cam or ?
[Re: BradH]
#2078416
05/22/16 07:50 PM
05/22/16 07:50 PM
BradH
CR?
60 ft?
Exhaust system? Do you run open headers? Let me also ask what the converter slippage % is, the 1/8 mile ET & MPH, and the RPM going thru the traps in the 1/4...
Re: New cam or ?
[Re: EDDIEB]
#2078488
05/22/16 10:49 PM
05/22/16 10:49 PM
Thumperdart
State of confusion
Like we talked, something is definitely goin on and the 60ft to me is where everything starts and needs to be fully rockin by the 330 then of course enuff fuel system to keep it charging forward. Is it spinning? Any video?
Re: New cam or ?
[Re: EDDIEB]
#2078489
05/22/16 10:50 PM
05/22/16 10:50 PM
MR_P_BODY
ran extensions and saw no gains ,different carb no gains,put trans brake in no change,it drives me nuts ,restall convertor no change just thinking I am missing something Your missing something with all those changes and didnt change your ET
Re: New cam or ?
[Re: sgcuda]
#2078502
05/22/16 11:05 PM
05/22/16 11:05 PM
Thumperdart
State of confusion
Have you checked for full throttle? Been there...........
Re: New cam or ?
[Re: EDDIEB]
#2078512
05/22/16 11:16 PM
05/22/16 11:16 PM
BradH
ran extensions and saw no gains ,different carb no gains,put trans brake in no change,it drives me nuts ,restall convertor no change just thinking I am missing something So, all those changes and it ran 10.4s at 128, regardless? That makes no sense... and a cam change isn't going to "fix" it, unless you've also wiped it and don't know it, yet.
