Re: Vacuum pump
[Re: maxie]
#2086367
06/05/16 01:22 PM
06/05/16 01:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Dont you drive a lot on the street.. if so I wouldnt run a full time vac pump... look into a electric one from GM trucks.. that way you can turn it off on the street.... JMO.. I'm going to look into a elec one myself... granted they dont pull as much vac but anything greater than zero pressure is a help.. unless you built it with low tension rings EDIT Oh.. forgot to say... both U will have botom... I welded this up for a big CI race engine that they had problems with.. we did this testing on the dyno first then on the track... worked out great
Re: Vacuum pump
[Re: bwhackd34]
#2086414
06/05/16 02:22 PM
06/05/16 02:22 PM
Posts: 8,048 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Did some research on vac pumps a couple yrs ago. The GZ pump seemed the best for the money. I used the electric pump for awhile . it only pulled 2" of vac. As Mike said, better than nothing.
Re: Vacuum pump
[Re: maxie]
#2086526
06/05/16 05:58 PM
06/05/16 05:58 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Looking into crankcase vacuum pumps and one that will mount on the water pump housing on a 426 hemi. I see where aerospace engineering makes one. What do you have? Pictures?
Thanks Scott Moroso do an adapter that mounts to the stock water pump housing See thread https://board.moparts.org/ubbthreads/ubbt...mp-systems.htmlHope this helps
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: Vacuum pump
[Re: bwhackd34]
#2086633
06/05/16 09:04 PM
06/05/16 09:04 PM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
I have a GZMotorsports on my iron w2 340 is that a Jesel belt drive
Re: Vacuum pump
[Re: mopar dave]
#2090080
06/11/16 12:33 PM
06/11/16 12:33 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Did some research on vac pumps a couple yrs ago. The GZ pump seemed the best for the money. I used the electric pump for awhile . it only pulled 2" of vac. As Mike said, better than nothing. Buddy of mine uses an electric pump for a GM S10 $125 New at Rock Auto on his 900HP 565" Bullet.....works perfectly and pulls a lot more than 2" of vac...??? Rickster
Re: Vacuum pump
[Re: maxie]
#2090148
06/11/16 02:59 PM
06/11/16 02:59 PM
Posts: 10,184 A Red State
SNK-EYZ
A Red State
I've been looking into running a vacuum pump on my 572 Hemi. On a hard pass it seems to build up crankcase pressure.
After talking to Clay Kossuth he recommended a late 90's GM electric vacuum pump. He said it's what they run on his wife Rosie's NSS car.
I need to run by their place and see how they set it up on the car. I'm planning on taking some pics of the setup and getting a parts list of what I'll need.
