Solid roller cam in a magnum block #2066830
05/03/16 11:13 PM
05/03/16 11:13 PM
So. Burlington, Vt.
fast68plymouth Offline OP
So. Burlington, Vt.
I have a customer who's looking to put a solid roller cam in a stroker small block that will be built from a magnum block.
Anyone know what lifters are the best fit, and just how much grinding is required to get them to work?
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2066854
05/03/16 11:50 PM
05/03/16 11:50 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Check these ones out and give him a call. I just bought a set for a 360 I am building and a test fit showed them sliding right in but I have an LA block (old style). I used the comps on my last build and had to do LOTS of grinding.
http://www.mrlperformance.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2066877
05/04/16 12:30 AM
05/04/16 12:30 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
MRLs in my Magnum 408, drp right in.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067156
05/04/16 02:23 PM
05/04/16 02:23 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
just to add...Magnum blocks don't oil trough the deck....you may need push rod oiling or have to modify the block for deck oiling.
Re: Solid roller cam in a magnum block [Re: B1MAXX] #2067197
05/04/16 03:15 PM
05/04/16 03:15 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I've done a couple motors with the MRL's and they look like they should clear but it's been a while since I had a Magnum block in front of me.
They will pushrod oil with no problem so they should be a good fit for the Magnum heads. In fact on my 59 degree 70 340 block I've restricted about 95% of the oil through the block. the .815 diameter rollers with direct oiling are a nice feature plus they are strong and light. I replaced a set of Morels on my 414 with the MRL's and they were about 3 ounces PER PAIR lighter.
Here's a pic, they look like they'll have plenty of top side clearance.
WIZE
In Car:
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067202
05/04/16 03:18 PM
05/04/16 03:18 PM
So. Burlington, Vt.
So. Burlington, Vt.
The block in question still has the oil feed holes for the LA style heads.
Thanks for the responses....... Sounds like the MRL's will get the job done.
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067205
05/04/16 03:20 PM
05/04/16 03:20 PM
BPE Offline
BPE  Offline
Comp 8043's will clear in a magnum block without grinding.
Rod
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067411
05/04/16 09:09 PM
05/04/16 09:09 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Yes, in my magnum lunati,s needed grinding, not the comp ones....
Dan
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067490
05/04/16 10:54 PM
05/04/16 10:54 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Magnum blocks from 92-95 still have the oil feed hole in the deck for LA heads, 96 to 2003 would have to be drilled.
MRL lifters will clear no problem in a magnum block I am running them in my 410 magnum stroker.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Solid roller cam in a magnum block [Re: slammedR/T] #2067523
05/04/16 11:28 PM
05/04/16 11:28 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Is this a 'for sure' cause.. that'll save me from one ginormous headache.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067544
05/05/16 12:06 AM
05/05/16 12:06 AM
slammedR/T Offline
slammedR/T  Offline
My 92 date code 360 magnum block I put into my fathers 1990 ramcharger has the oil feed hole. The 95 date code magnum block I'm currently using for my 410 stroker has the oil feed hole. the stock 2000 date code magnum block I had doesn't have the feed but a machine shop should have no issue drilling the feed hole by using a head gasket as a reference.
racemagnum
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067562
05/05/16 12:44 AM
05/05/16 12:44 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have only seen a few early ones with it, no ryme or reason to it, I have a 93 5.9 without it. I have a friend that has a 97 with it, that is by far the latest one I seen.
It will take an above average machine shop, it needs a real long skinney bit and it has a weird angle on two planes and the target hole in the cam bearing is not big.
Re: Solid roller cam in a magnum block [Re: fast68plymouth] #2067569
05/05/16 12:54 AM
05/05/16 12:54 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Yes, 93-94 blocks retained the LA oil feeds....that makes them desirable around here
Dan
'67 Barracuda
408ci
